RV.Net Open Roads Forum: Tech Issues: Elect. start generator.
 > Elect. start generator.
2oldman
NM
Posted: 08/01/21 07:39am Link  |  Quote  |  Print  |  Notify Moderator
Don & Barb Bogue wrote:
Last time edit.shut down our area was at 3-am. I work up at 330. could not breathe.
I'm not sure what that means, but an inverter would be much better than a generator. Not too many places you're going to be able to run a generator all night.
Lynnmor
Red Lion
Posted: 08/01/21 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Seon wrote:
WNYBob wrote:
Here is a 2300 watt inverter/ Generator with electric start.
Electric start generator
Awful pricey for a 2300w.
Since they are sold out the price must be acceptable.
theoldwizard1
SE MI
Posted: 08/01/21 09:51am Link  |  Quote  |  Print  |  Notify Moderator
IMHO, a good set of batteries and a small inverter/charger/automatic transfer would be optimal. Yes, it would be a lot more expensive, but no one is going to have to hook up anything when the power goes out.
pianotuna
Regina, SK, Canada
Posted: 08/01/21 10:56am Link  |  Quote  |  Print  |  Notify Moderator
o2 generators are power hungry devices. They are essentially a compressor that is constant run. It would take a massive battery bank to run one overnight.
There are portable units (back pack) that use less energy, but they are $3K and up. They may not have the flow rate that the OP needs.
Regards, Don
2oldman
NM
Posted: 08/01/21 11:09am Link  |  Quote  |  Print  |  Notify Moderator
That's not what I find. They all have small batteries that can run it from 4-10 hours.
The internet is really something. 5 minutes after making this post I got an ad on my FB page for an o2 concentrator.
* This post was edited 08/01/21 11:15am by 2oldman *
theoldwizard1
SE MI
Posted: 08/01/21 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
With no specification on power draw, we are all just shooting in the dark !
The Samlex EVO-1212F is a simple "plug and play"
Just add batteries like a Zooms 12V 200Ah LiFePO4 Battery Lithium Iron Phosphate Battery Deep Cycle
[image].
You also need a some battery cables and a mega-fuse.
CharlesinGA
South of Atlanta, Georgia
Posted: 08/01/21 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
While pricey, for night time use, to avoid the noise of a generator, you should consider a Bluetti portable power station (lithium batteries, charger, inverter, power outlets, all in one box) https://www.bluettipower.com/
There are other brands also, this is the only one I can think of off hand.
Charles
'03 Ram 2500 CTD, 5.9HO six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. previously 2008 Thor/Dutchman Freedom Spirit 180. SOLD - 2007 Winnebago View 23H Motorhome.
pianotuna
Regina, SK, Canada
Posted: 08/01/21 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna
Regina, SK, Canada
Posted: 08/01/21 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 08/01/21 09:47pm by pianotuna *
PatJ
Eastern WA
Posted: 08/01/21 11:11pm Link  |  Quote  |  Print  |  Notify Moderator
Re-reading your post, it sounds like you are not camping but instead preparing at home for when your local utility shuts you down for whatever reason (or no reason) with little or no warning.
If I'm that reading correctly, your not moving it and its basically life or death. In that case in my opinion I would get the Honda 3000 (or two, for redundancy.) The electric start add-on kits for the 2000 are slick but I'm not sure I'd trust a Chinese add-on kit in this critical application.
If I'm mis-reading and you are in fact mobile, I would still get the Honda 3000. And if you end up somewhere where someone has an issue with a EU3000 running at idle overnight to sustain life, I'd tell them tough ****.
Patrick
