RV.Net Open Roads Forum: Tech Issues: uneven tire wear
 > uneven tire wear
rvshrinker
Beautiful Pacific Northwest
Posted: 08/01/21 11:22am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2017 Outdoors RV with about 12,500 miles on it.
Last summer I saw the left rear tire was prematurely wearing. The other 3 tires look great.
This summer after a 2500 mile trip, the tire is really worn. It needs to be replaced. The other 3 tires look great.
The wear is even, in the center/broad middle of the tire.
These are Goodyear E rated trailer tires, not some cheap off brand tire.
From reading on line the causes of unequal tire wear include:
1. bad axle/spindle -
2. over/underinflation - I fill to exactly 80 psi before every trip and the tires hold their pressure well
3. uneven loading - this trailer has the pantry above that area. Food is food, doesn’t weigh 500 pounds or anything. Opposite side is the refrigerator which wouldn’t seem substantially lighter
4. just a bad tire
Other thoughts?
I need to replace the tire and plan to use the spare to do it, which should have at least a couple more years of life on it based on age. Then I’ll replace all 5 tires.
Anza-Borrego Desert SP area
Posted: 08/01/21 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Bent axle can. At four, almost five years old, replace them all. How they look is not the best way to determine tire replacement. Time is.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
HappyKayakers
Somewhere in the USA
Posted: 08/01/21 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
Wear in the middle of the tire normally indicates overinflation. You said you air up all tires to 80 psi. The load that tire is carrying may just be too light for 80 psi. There are some places that do individual wheel weights, instead of by axle. You might want to check it out to see if you need to adjust tire pressures.
Joe and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
Campground Tees
Roger10378
Goodrich, MI.
Posted: 08/01/21 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
It could be a bent axle. If it is bent so that there is a lot of toe it can wear evenly across the tire. Put a strait edge on the tire and see if it is parallel with the one in front of it.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
rvshrinker
Posted: 08/02/21 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Can you explain what you mean? see if the second tire is askance from the first?
rvshrinker
Posted: 08/02/21 09:47am Link  |  Quote  |  Print  |  Notify Moderator
I wondered about overinflation, but it is the only 1 of 4 tires with this problem and there’s really not that much variability in the weight. Also everything I read said blowout resistance was best at 80 (max) psi for trailer tires, nothing said anything about reducing inflation for reduced loads.
HappyKayakers
Posted: 08/02/21 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Someplace that weighs each wheel individually will tell you exactly instead of guessing. At the very least, it would prove or disprove conclusively one possible problem. Here's a link to the Goodyear load/inflation chart. Please note this chart is for towable RVs, as in ST tires. https://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
Dusty R
Charlotte Michigan 48813
Posted: 08/02/21 11:18am Link  |  Quote  |  Print  |  Notify Moderator
I bought a new tandem axel trailer and after pulling it many miles discovered that the u-bolts on one end of one axel were very loose, which caused bad tire wear.
Roger10378
Goodrich, MI.
Posted: 08/02/21 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
It is hard to explain with just words but I haven't figured out how to add a drawing so I will give it a try. If you look at the tires on an axle from above and they are closer together at the front than the rear that is toe in. If they are closer at the rear that is toe out. In most situations there is a very little toe in. If there is too much toe the tire is dragging down the road which will wear it out sooner than it should. By placing a strait edge along each tire it will show if there is a large difference in toe. If that is the case you need to take it to a trailer service center where they can correct the problem.
Posted: 08/02/21 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
That’s a new one on me.
Barring some really unusual situation, like the equalizer being hung up on a leaf spring tandem axle, or a torsion axle tandem trailer that is significantly nose up or down, how would one get a significantly different load on one tire compared to the one just ahead or behind it.
2017 Heartland Torque T29
 > uneven tire wear
