RV.Net Open Roads Forum: Need help for locating a new Generator box
 > Need help for locating a new Generator box
Johnnydo2
Antioch,ca
Posted: 08/01/21 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
I just bought a 20' travel trailer and want to mount a box on back bumper for my 3200w Firman generator to run the generator in.
I need to know where to find such a box and accessories.
Thank you.
Johnnydo2
NamMedevac 70
Reno
Posted: 08/01/21 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
I sometimes carry my Firman 2000W genny on a HF cargo carrier mounted to my truck trailer hitch and other times carry it in the bed and I have seen similar cargo carriers mounted behind TT. They may have a hitch on the trailer or bolt the carrier to the bumper. I have a thick Honda cover for my Firman and then wrap it in large black garbage bag if suspect wet conditions. Carry the accessories in a small rubber mate container inside the camper shell.
2oldman
NM
Posted: 08/01/21 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
Running it like that makes it louder and vibrates the trailer.
bgum
South Louisiana
Posted: 08/01/21 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
Check tractor supply or harbor freight.
NamMedevac 70
Reno
Posted: 08/01/21 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
Mine weighs less than 50lbs and I place it away from the truck/trailer usually on a small sturdy stool or campground table off the ground. Maybe OP can find a large rubbermaid like container for the firman just for carrying purpose and use it on a cargo carrier. I use different size rubbermaids for storage and they work great. I have seen boxes like he wants on the internet using Google search. To each his own
Seon
Lake Camanche, CA
Posted: 08/01/21 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Google "travel trailer generator mount"
Maybe one of these will work for you.
canoe on top
Denver, CO, US
Posted: 08/01/21 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like that weighs 92 lbs dry. Figure 100 with fuel. Looking at the leverage a platform like the one pictured above would have, I would not hang that on a flimsy trailer bumper. I would suggest a trailer hitch welded to the frame.
theoldwizard1
SE MI
Posted: 08/02/21 02:57am Link  |  Quote  |  Print  |  Notify Moderator
Exposed generators attract THIEVES !
Lynnmor
Red Lion
Posted: 08/02/21 06:52am Link  |  Quote  |  Print  |  Notify Moderator
In addition to the 100 lbs, add the platform weight. No way would I consider the idea.
valhalla360
No paticular place.
Posted: 08/02/21 07:58am Link  |  Quote  |  Print  |  Notify Moderator
I like the A-frame mounted one. It adds to your tongue weight (as long as the truck has sufficient payload), which is generally a good thing for towing.
On the rear bumper of a 20ft trailer, be sure to check the tongue weight. If it's OK but borderline, that may reduce the tongue weight enough to make towing unstable.
Assuming 150lb with the mount and cover...it could easily be taking 100lb off the tongue weight.
If the trailer weighs in at say 4000lb loaded with a 450lb hitch weight (11.25%) and you drop it to 350lb suddenly you are at 8.75%. 10% is the typical break point where things get squirrely. Though higher is better.
It tends to be less of a concern on larger trailers. A 9000lb trailer with 11.25% tongue with will be 1012lb...lose 100lb and it's still at 10.1%. (5th wheels with 20-25% pin weight and wheels placed further back, tend to be even less affected).
As someone else mentioned, the rear bumper is not a structural member, so I wouldn't trust it to support much of anything.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
