RV.Net Open Roads Forum: 2011 tiffin 32ca - how to remove electronic captain chair
 > 2011 tiffin 32ca - how to remove electronic captain chair
Big Jimmy
Livermore
Posted: 08/01/21 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
we own a 2011 tiffin 32ca and the front captain chairs (electronic) are cracking and looking bad and would like to remove them to have recovered. my question: is there an easy way to remove them?
thanks for your help!
Busdriver
Shepherdsville Ky 40165
Posted: 08/01/21 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
Try U-TUBE
Busdriver 2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLS
rgatijnet1
Posted: 08/01/21 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
Most captains seats have 4 bolts to remove entirely them WITH the base or 4 smaller bolts to remove just the seat from the slide mechanism. The electrics just unplug. Pretty simple but the bolts can be a little difficult to reach and you need to be careful with your fingers so you don't pinch them.
dougrainer
Carrolton, Texas
Posted: 08/01/21 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
There are 8 bolts/nuts. On the bottom of the electric mount you will see 4- 1/2 wrench nuts that come off the studs. Then you disconnect the 2 wire 12 volt harness plug below the pedestal mount behind the chair. Depending on the Seat/shoulder belt arrangement, you may have to remove the seat belt bolts on each side of the mount pedestal. THEN (chair with electric mechanism is heavy and bulky), you lay the chair down in the aisle by the couch and you will see 4 bolts(also 1/2 inch wrench) with nuts and a 3/8 deep washer for each bolt that you remove to remove the electric mechanism from the seat. You will also have to remove the 6 way seat switch on the side skirt and they usually have just 2 screws. You also have to remove the seat swivel cable mount from the bottom of the seat pedestal. DO THIS FIRST!. Doug
