RV.Net Open Roads Forum: Fifth-Wheels: Lost Power to Landing Gear and Slides
 > Lost Power to Landing Gear and Slides
fyrmnk
Kansas City
Posted: 08/02/21 05:17am Link  |  Quote  |  Print  |  Notify Moderator
Hi all, long post so bear with me as I explain lead up and problems. Manual seitches, lost remote. 2010 Montana Mountaineer 345 DBQ
Just took a trip from KC to Corpus. Horrible rough roads. Motor for back stabilizers broke off along the way and is gone, as did the fridge door (not gone [emoticon]).
Landing gear and slides worked fine to unhook. When hooking up to leave, landing gear was working, went to adjust truck, and wouldn’t work, tried slides and no luck either. Fuses good.
On remote board (remote lost). No power on “to manual switches” connections). Jumper used from always + to slides got rooms in, but nothing on landing gear, hand cranked to get on truck.
Got home, Found no power to fuse side of remote board switches, a purple wire feeding. Did jumper around and manual slides worked as did landing gear. Cut purple feed and hard connected purple to battery connection, gear and slides worked, then fuse blew.
Guessing purple is a switch leg needing it’s own power, but banging my head on the wall. Of course everything’s concealed. Purple feed runs under slides to “nowhere.”
Just weird I can jumper slides but not landing gear on board. Makes no sense to me. Not getting full power to lost motor connections either. Know something came loose but where and how to bypass? Thanks in advance for any insight.
2010 Montana Mountaineer 345DBQ 37' 5th Wheel
Previous: 2005 Coachmen Capri Ruby Edition 28' Bumper Pull
grizz272
frozen tundra, WI
Posted: 08/05/21 12:24am Link  |  Quote  |  Print  |  Notify Moderator
IS your battery disconnect switch on or off. I had a similar problem after a real rough trip and found the disconnect had been bumped and turn off.
fyrmnk
Kansas City
Posted: 08/05/21 07:24am Link  |  Quote  |  Print  |  Notify Moderator
Switch is on. Flipped off and on, no change.
RKW
Four Corners, New Mexico
Posted: 08/05/21 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Sometimes manufacturers sneak in an inline fuse in the oddest places. By inline fuse I mean one that is spliced in somewhere along the run of a wire, and no where near the fuse box. I've seen them tucked out of sight. Just spitballing here...
* This post was edited 08/05/21 10:56am by RKW *
Ryan
  • 2015 Ford F250
  • 2015 Rockwood Signature Ultralite 8280 WS
  • Dual Honda EU2000i Generators
    The wages of sin are death; but after they're done taking out taxes, it's just a tired feeling.
  • fyrmnk
    Kansas City
    Posted: 08/05/21 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
    Thanks, there is an inline fuse fed by the dead wire, and when I bypassed the dead wire, it blew. Will look to see if I can find another one. Would sure be nice if they provided a schematic [emoticon]
    jaycocamprs
    Ringgold Georgia
    Posted: 08/11/21 06:09am Link  |  Quote  |  Print  |  Notify Moderator
    If your 10 Mountaineer wired like our 11, then the landing rear, hydraulic pump, rear stabilizers, awning & scare lights all run through the remote control brain. Do any of the others work. This is the one point all of these systems meet.
    I would 1st look at the switches, just check they are plugged in good & not damaged. 2nd look over the wiring for the rear stabilizers. Make sure they aren't shorting out.
    Not sure how you jumpered the slides. But the main power feed does not go through the brain box, only the control. Main power goes to switching solenoid, that is operated by the control board. Landing gear doesn't draw as many amps, so it appears to run through the control board.
    2018 Silverado 3500 DRW
    2011 Montana Mountaineer 285RLD
