RV.Net Open Roads Forum: Class A Motorhomes: Alison transmission computer
 > Alison transmission computer
Tom/Barb
Oak Harbor, Wa
Posted: 08/02/21 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Most probable cause ?
no shift panel lights,
no start.
ACC side of the ignition works, all systems work.
IGN side of the ignition works normal.
Strat position goes dead when you try to start.
Thanks for the help.
Mel Stuplich
Wausau, WI
Posted: 08/02/21 11:01am Link  |  Quote  |  Print  |  Notify Moderator
Tom/Barb
No 12V power to the Allison VIM ... (blown fuse?/ bad wire?)
Tom/Barb
Oak Harbor, Wa
Posted: 08/02/21 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
Mel Stuplich wrote:
Tom/Barb
VIM. = ?
all fuses have been checked
all relays have been checked
all system operating.
except the start position.
the starter/relay/ ignition switch/ have been changed.
nothing fixed it.
larry cad
ohio
Posted: 08/02/21 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
Shift panel lights went out on mine, lost power to the panel. Apparently broken wire. Shop installed a new wire. All good.
Our Travel Blog
donkeydew
OR
Posted: 08/02/21 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
it can be many things when my cat low fuel pressure sensor when out it went blank
mobile mechanic scanned the engine and replaced the sensor all was good the allison pad lit right back up. i had called coach net and the first thing they ask was if the pad was lit,when i said no the ask if i needed a tow or or mobile mech.
kane8907
East Brunswick,NJ
Posted: 08/09/21 05:23am Link  |  Quote  |  Print  |  Notify Moderator
How much does it cost to change an pressure sensor in a repair shop?
**Link Removed**
* This post was edited 08/10/21 02:05pm by an administrator/moderator *
ArchHoagland
Clovis, CA, USA
Posted: 08/10/21 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
Any luck yet? Besides bad luck....
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
gatorcq
Arizona
Posted: 08/13/21 05:57am Link  |  Quote  |  Print  |  Notify Moderator
A friend went through this. Bad ground on/near the TCM.
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
Tom/Barb
Oak Harbor, Wa
Posted: 08/17/21 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
We have discovered the problem,, we changed the Transmission ECU,, it did not fix the problem,,changing the major Battery cable fixed it.
corrosion ate the end of the cable nearly off. it will show continuity, but when place a load the cable would fail.
ArchHoagland
Clovis, CA, USA
Posted: 08/18/21 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the update, glad to hear it's fixed and I'll bet you are too...
