RV.Net Open Roads Forum: 6 or 12 That is the question
 > 6 or 12 That is the question
Cummins12V98
on the road
Posted: 08/03/21 10:20am Link  |  Quote  |  Print  |  Notify Moderator
Friends just bought a new 32-34' Cougar 5er (much better quality than I expected) . They have not added the batteries yet at the Dealer. They have a Solar Panel on the roof and a 2,000 Inverter. I told them to be sure they get two 6V batteries and when asked why I couldn't give an exact reason other than it's the best way to go.
So please help either tell me I am wrong and why or that I am correct and why.
Thanks!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ktmrfs
Portland, Oregon
Posted: 08/03/21 10:36am Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
If they expect to use the full 2000W or even 1000W from the inverter to run a microwave, don't expect a pair of 6V to work unless they are 80%+ charged. Internal resistance of 6V is the downfall for heavy loads.
If they don't dry camp much if at all, stick with a pair of the typical "marine" 12V, much less expensive and will serve the purpose well.
If they dry camp a lot, usually only use lights, ceiling vent fan, furnace etc. then a pair of GC is a good choice.
If the dry camp a lot and want to use the microwave or heavy draws (>50ish amps) often, two choices, 4 GC2's, or a pair of real 12V deep discharge batteries.
And more than likely the trailer has a WFCO charger. if they dry camp and want to charge the batteries from a generator quickly don't expect the WFCO to do much. They are seldom if ever known to go into boost mode, instead only stuffing 15A or so into the bank. Toss it out and do a drop in PD replacement and easily get 55A of charging current when needed.
If they don't dry camp much, no need to replace the WFCO
My $0.02 worth from 10 years experience with batteries, camping etc. for us and many friends we camp with.
2011 Keystone Outback 295RE
opnspaces
San Diego Ca
Posted: 08/03/21 10:54am Link  |  Quote  |  Print  |  Notify Moderator
If they dry camp a lot and need the batteries then the 6 volts are the way to go. They are a true deep cycle battery that can withstand deeper draws on their reserves and not get damaged. But the downside as ktmrfs states is the 6 volts have a high resistance. So for normal loads like lights and television and water pump and charging laptops etc they are fine. But if you try to run the microwave through an inverter they will not be able to keep up with the current draw.
If they mostly have electrical hookups when camping then they should go with 12 volts as they are cheaper and don't really get drawn down between campsites.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Cummins12V98
on the road
Posted: 08/03/21 11:09am Link  |  Quote  |  Print  |  Notify Moderator
Unlikely they would be using the Micro as it's a big draw so let's eliminate that from the equation. I assume the Inverter is item specific??? I have a 1000 and it's only hooked to the Residential Refrigerator. They have dual WH along with a dual Refrigerator.
Monterey, California
Posted: 08/03/21 11:37am Link  |  Quote  |  Print  |  Notify Moderator
One solar panel on the roof isn’t likely to refill even two batteries…6 or 12…for “normal” use much less if they use the inverter much.
Super_Dave
Harrisville, UT
Posted: 08/03/21 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
The fact that the unit has solar indicates the intention to dry camp. In that scenario, it is all about amp hour capacity. 2 - Group 29 or 31 deep cycles are going to be right around 100 amp hours each. That should be compared to the amp hour rating of a single 6V battery.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
Posted: 08/03/21 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
I don't follow. Typical 200-235A 6V GC2s are Under $100 to about $175/ea
Typical 12V RV/Marine are (not deep cycle) and under $100 to under $200. True deep cycles like the Trojan batteries are $200+/ea for 150ah batteries.
Not sure where your much less expensive statement is derived. Apples to apples they're pretty close in cost.
2017 Heartland Torque T29
Posted: 08/03/21 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you!
This is what I think I'm seeing with my camper. It has a 55A WFCO all in one power center deal. Last 2 AF TCs had PD converters and they worked GREAT!
After reading the WFCO literature it "warned" that one may not "see" the 14+V charging mode, but "it's there" lol.
Well, I didn't see that voltage and voltage is voltage. And likely why I have issue charging up my two GC2s fully by running the genny for just a couple-3 hours when dry camping.
Posted: 08/03/21 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
12V, unless the aforementioned high inverter output is desired, and they are only installing 2 batteries, 6V all the way!
Longer lifespan (thicker plates) including the typical battery killer which is re-charging from deep discharges.
There's more to it though. FLA which require maintenance (water), vs SLA which theoretically don't (unless they get cooked real good) vs
AGM which generally last longer than FLA/SLA and seem a bit more "reliable" to me vs if one is serious aboot dry camping and never in cold weather then some of the "bargain" LiFEPO4 options are beginning to seem attractive if used within their limitations and long life/capacity/lightweight is a concern.
theoldwizard1
SE MI
Posted: 08/03/21 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
Simply put, 6V golf cart batteries are designed and manufactured differently. Specifically they are design for multiple deep discharge (about 25%)/charge cycles. 99% of the 12V batteries will have a shorter life if you discharge them that much.
A pair of golf cart batteries can store about 220Ah of energy. A Group 24 RV battery, only 75Ah. Even the larger Group 31 batteries can only store about 100Ah.
Yes, a pair of golf cart batteries will cost more than a single 12V, but not twice as much?
