RV.Net Open Roads Forum: Tech Issues: Talk about voltage drop (12v)
 > Talk about voltage drop (12v)
wopachop
Who run bartertown
Posted: 08/03/21 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
Have the trailer in boondocking mode. Some old batteries and 150w of solar. The batteries are showing 13v. I have a little 300w inverter to charge my laptop and things. 14 gauge wire is feeding the little inverter and the USB panel.
Doesnt that seem weird its dropping below 12v and only pulling 3amps?
wopachop
Who run bartertown
Posted: 08/03/21 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Should mention the circuit is roughly 15 feet long and i believe 14 gauge wire feeds it. I tapped in and added another couple feet of 14 gauge wire up to the USB panel.
Its been a couple years but im pretty sure im on a dedicated circuit. I might have tapped into the electric awning. Point being i dont think there is any other load besides the 3amps.
enblethen
Moses Lake, WA
Posted: 08/03/21 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds about right!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
theoldwizard1
SE MI
Posted: 08/03/21 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
What brand is that panel meter ?
Some inexpensive meters are known to be off by 10%.
time2roll
Posted: 08/03/21 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
#14 and 300 watts... is that the fuse? Or is that by design so the inverter will drop out before the fire ensues?
675w Solar pictures back up
wopachop
Who run bartertown
Posted: 08/03/21 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
Hmm good point. It's that little red cube. Maybe a 150W.
enblethen
Moses Lake, WA
Posted: 08/03/21 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
The meter and LEDs add to the load. There is losses within the unit that draws power.
pianotuna
Regina, SK, Canada
Posted: 08/03/21 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
#10 wire would be much better. I would expect 7.5% voltage drop with 15 feet of #14 and the loads.
Regards, Don
Posted: 08/03/21 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
300 watts is about 30 amps at the battery 14GA is good for half that at 120 volt and even less at 12 volt due to voltage drop.
Plus there is a voltage drop INTERNAL to the batteries (I do not know how much)
The key to battery/inverter is three fold
One, Keep the leads as short as you can but do not mount the inverter inside the same space as the batteries
Two HEAVY cable for a 300 watt Starter cable works very well and is low cost up to around 750 watts it works well. long about 1000 it might be a bit...er.. anemic
3: for as much of the run tape or wire loom the cables like this ============
Side by side. This is more important on larger inverters.
AND MORE battery never hurts..
DEEP CYCLE batteries work best for House use.
(As opposed to MARINE/deep cycle) note how I use case on those)
wopachop
Who run bartertown
Posted: 08/03/21 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
I'm seeing voltage drop along the wire correct? Not battery sag? The test is during the day with solar hooked up. Only drawing 3amps.
Why dont I see similar voltage drop while on shore power? Pretend the Led display read 14v. When I apply the same 3a load why doesnt the display show 12-13 volts?
I understand that higher voltage sags less. But we are only talking the difference of 12v boondocking to 14v on shore power.
