RV.Net Open Roads Forum: Tech Issues: Surge Protector - Hardwired without transfer switch?
 > Surge Protector - Hardwired without transfer switch?
Baja Man
Inland Empire, CA
Posted: 08/04/21 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
My new to me TT does not have a surge protector (SP), portable or hardwired. It also does not have a transfer switch (TS). I have not yet verified, but I assume the power cord used to connect my trailer to a power source (ex. power pedestal at campground) is connected directly to inverter/charger box where 120V and 12V fuses/breakers are located.
The last hardwired SP I installed was in my TH that had a built in genny. I installed the SP before the TS.
I want to install a SP in my TT. MY TT is 30amp.
Do I need to have a TS to utilize ALL aspects/benefits of the SP?
Or can the SP be installed anywhere between the power cord and the inverter/charger?
Thanks!
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 trans
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
TUCQUALA
Kennewick, WA
Posted: 08/04/21 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
Have installed a 30A hardwired Hughes Watchdog. Didn't put in a "switch" (aSSume you mean a switch to bypass the SP) but will be doing it soon. Found out that the SP would kick out when running AC on generator due to voltage dropping below (very momentary!!) the "protection" low limit. Since trailer is now on our own 10 acres (not travelling anywhere), only running when needed on generator, I have disconnected the SP so we can run the AC!! Hughes sees no problem with the unit, the gen mfg doesn't see any problem with the genny!! So, no SP being used at this time!!
Just thought I'd mention it to help with your decision!!
So, are you happy with your Outdoors "replacement"??!!
'16 Outdoors Timber Ridge 280RKS
Reese 1700# Trunnion w/ DualCam HP
'03 EXCURSION XLT V10 4.30 Axles
time2roll
Posted: 08/04/21 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
No TS needed unless you add a second power source such as an inverter.
Just remove the wire from the main panel and connect to the SP inlet. Get a like piece of wire and connect the SP out to the panel. Done. This makes it easy to remove if needed.
675w Solar pictures back up
pianotuna
Regina, SK, Canada
Posted: 08/04/21 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
No need for a transfer switch. Do get one with a bypass switch. It appears that Hughes now makes a better surge protector than either Surge Guard or P.I.
https://hughesautoformers.com/power-watchdog-smart-surge-protectors/
Regards, Don
wildtoad
Blythewood, SC
Posted: 08/04/21 11:49pm Link  |  Quote  |  Print  |  Notify Moderator
If you don’t have a generator why do you think you need a transfer switch? Transfer between what? Just get a SP to sit between your 30 amp plug and the power source.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Sandia Man
Rio Rancho, NM
Posted: 08/05/21 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Nothing needed for your scenario, with our TH we either plugged directly into shorepower with our surge protector or plugged power cord into dedicated generator outlet provided on our rig. With our class A nothing has changed for the most part, we plug power cord with surge protector into power pedestal, transfer switch always prioritizes Onan power when genny is running anyway. We love our Hughes SP, works flawlessly and the info provided via bluetooth is quite in depth.
Baja Man
Inland Empire, CA
Posted: 08/30/21 09:55am Link  |  Quote  |  Print  |  Notify Moderator
Does the wiring (no transfer switch) change or is the SP affected when I plug my RV 30amp power cord directly to my inverter portable gennys?
Tuquala: Just getting her dialed in! It's a very nice floor plan but quality is not as high as ORV....but neither is the price! Time will tell how she holds up.
Baja Man
Inland Empire, CA
Posted: 08/30/21 10:53am Link  |  Quote  |  Print  |  Notify Moderator
Tuquala....
Does the Hughes unit have a bypass switch? The Progressive Industries unit I purchased has one. I believe these are what are needed for the low voltage via inverter/genny.
Also, you do not travel with trailer any longer?
DrewE
Vermont
Posted: 08/30/21 10:54am Link  |  Quote  |  Print  |  Notify Moderator
The wiring in the trailer doesn't change when you plug into your own generator instead of the utility company's generators (which may be many miles away somewhere on the grid). The only negative with a surge protector may be that it detects the unbonded ground and neutral on the generator as an open ground and complains about that, if it's a decent EMS unit. The solution to that is pretty simple: either bypass the EMS, if it has a bypass switch, or plug a bonding plug into one of the outlets on the generator. A quick search of the forum will show what a bonding plug is and how to make one; it just connects the neutral to the ground on the generator.
TUCQUALA
Kennewick, WA
Posted: 08/30/21 11:10am Link  |  Quote  |  Print  |  Notify Moderator
Baja, no bypass on the Hughes. Maybe one of its shortcomings!! It is bypassed, power from socket direct into trlr like it was. Don't travel anymore at the moment, trailer is up on land we purchased last year. May put in a quick connect so I can easily go between the Hughes and direct input if and when needed!!
