RV.Net Open Roads Forum: Class A Motorhomes: Leveling Jack Pads/Slide Out Supports
 > Leveling Jack Pads/Slide Out Supports
Alex and Tee
Jacksonville , FL
Posted: 08/04/21 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
Who uses them, who doesn’t and why.
Thank you!
Alex & Teresa
2022 Allegro Open Road
2021 Colorado 4x4
CA Traveler
The Western States
Posted: 08/04/21 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Only used jack pads if needed or required.
Slide out supports - never, what happens if the RV drops for some reason? Not to mention required support for a slide suggest marginal design.
2014 Grand Cherokee Overland
Bob
rk911
DuPage County
Posted: 08/04/21 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you!
i use jack pads only on soft ground or when requiresd by park owners. slide out supports? never as they are not needed nor recommended by mfg.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
crawford
Dandridge Tenn.
Posted: 08/04/21 11:31pm Link  |  Quote  |  Print  |  Notify Moderator
I use jack pads first mine when first time used they press them self's inside of opening so now they are locked on. I like have a larger foot print and some parks require something under jack so not to hurt concrete pad you are parked on. Just say you have a 10 inch you may have 14 to 16 in base it make a difference in sand or gravel.
Change from a c class to a A class Georgetown 07 triple slide
wildtoad
Blythewood, SC
Posted: 08/04/21 11:39pm Link  |  Quote  |  Print  |  Notify Moderator
Pads only needed if park says so, or on hot asphalt, soft sand/dirt. If you think you need them (or sakes guy says you need them) to support a slide then get slide/RV fixed/walk away.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
scbwr
North Ridgeville, OH
Posted: 08/05/21 02:50am Link  |  Quote  |  Print  |  Notify Moderator
I put SnapPads on my MH this year and I really like them. I don't have to worry about campgrounds that request you use pads.
Slide out supports....never. Potential for damage exceeds any benefits, and any slide out I've had never needed any stabilization.
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
craig7h
Branson MO area
Posted: 08/05/21 05:22am Link  |  Quote  |  Print  |  Notify Moderator
It a great idea to always carry jack pads of some sort with you. They are mainly used for soft ground or like stated when the park requires it. After using both wood planks and the lego type blocks, both of which I had problems with. I ended up getting level pads from big foot and boy are they special and great. https://www.outriggerpads.com/
I also way back 4 rigs ago thought I needed those slide out supports. I bought a pair, there great for holding things up in my work shed. Nothing about them is good for and RV stay away from them period!
Good luck stay safe
Itasca Meridian SE 36g
Road Master Tow Dolly
Sandia Man
Rio Rancho, NM
Posted: 08/05/21 08:23am Link  |  Quote  |  Print  |  Notify Moderator
We do exactly as the consensus indicates for this post, jackpads as circumstances dictate and a big never for slideout supports.
Alex and Tee
Jacksonville , FL
Posted: 08/05/21 11:52am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for everyone's input. Kind of verifies what I've been thinking.
Blackdiamond
So. Cal
Posted: 08/05/21 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
I don't use either
03' Fleetwood Southwind 32VS
Enclosed Trailer hauling the toys
05 525 EXC KTM
15' FE350s Husqvarna/KTM
07 Rhino, long travel, 4 seater
