RV.Net Open Roads Forum: Tech Issues: AC Hard start additions
 > AC Hard start additions
popeyemth
owensboro ky
Posted: 08/05/21 08:44am Link  |  Quote  |  Print  |  Notify Moderator
Any new developments (in the last couple years) to the problem of starting/running a Dometic 13500 AC unit with a generator?
Thanks,Mike
"wine is a constant proof that God loves us, and loves to see us happy" ben franklin
vermilye
Oswego, NY, USA
Posted: 08/05/21 08:49am Link  |  Quote  |  Print  |  Notify Moderator
I don't believe they are within the last two years, but the Micro Air Easy Start is a great solution.
Jon Vermilye My Travel Blog
My Photo & RV link blog
Sandia Man
Rio Rancho, NM
Posted: 08/05/21 08:51am Link  |  Quote  |  Print  |  Notify Moderator
I don't know of any new developments if indicating 2K watt gennies, we have never had any issues to speak of since we use a 3K watt genny at a minimum for running our RV AC unit, no problems even at higher elevations.
2oldman
NM
Posted: 08/05/21 09:21am Link  |  Quote  |  Print  |  Notify Moderator
Get more generator.
ktmrfs
Portland, Oregon
Posted: 08/05/21 10:34am Link  |  Quote  |  Print  |  Notify Moderator
yup easy start. The only downside is at high altitude (>3500ft or so) a honda 2000 will run out of umph and shut down. A honda 2200 will run a coleman mach III or dometic at 7,000ft+ based on our experience.
2011 Keystone Outback 295RE
jjrbus
FT Myers FL
Posted: 08/05/21 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
Rumor has it that some of the new roof air have a hard start installed at the factory. If they are no one is advertising it!
I got some bad info on the net then experimented a bit. I run an 8000 btu window unit with a Honda 2000, added a hard start an run the Honda in ECO mode!
I would have installed a mini split years ago but do not have room for the inside unit.
2oldman
NM
Posted: 08/05/21 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
good one
* This post was edited 08/05/21 02:03pm by 2oldman *
3 tons
NV.
Posted: 08/05/21 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Another well founded internet rumor??
3 tons
ktmrfs
Portland, Oregon
Posted: 08/05/21 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
a lot of the "hard starts" installed at the factory are the same as what is in the over the counter AC units, a start cap for the compressor. Coleman and dometic sell OEM units w/o any start cap for the compressor. grunt grunt.
If the AC already has a start cap, a "hard start" cap may help some, but likely not much. Even with a hard start cap installed Locked rotor amps is still in the 50A range, well beyond what most 2000VA or so generators can supply for enough time to get the motor running enough to get the back EMF up to the point that the running amps are in the 15A range.
I graphed the start current with a micro air on My Coleman Mach III. PEAK start current is 20A for < 1 second, well within the capability of most 2000VA generators, even in eco mode. It took 3 or 4 of the "start learning cycles" that are called out to get their. Initially peak starting current was 45A w/o the micro air.
philh
Belleville MI
Posted: 08/05/21 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
microaire easy start
