RV.Net Open Roads Forum: Truck Campers: Hit the scales again this morning, PERFECT!
 > Hit the scales again this morning, PERFECT!
d3500ram
Colorado
Posted: 08/05/21 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
I take it to mean that he is right at the numbers for the respective axles and over the GVWR which is entirely possible.
When I had mine, I was well under each axle rating and over the GVWR.
I think it is a misspoke word...
I think he meant: The WEIGHT (not rear) is over by quite a bit. The trucks GVWR is only 9500.
mountainkowboy
Socal/NE Oregon
Posted: 08/05/21 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
We sit at GVWR, floating between 9,800 to 10,600 depending on how were packed. But under on manufacture axles ratings. In the 90's it was more for warranty than anything else. If my truck didn't come with a bed the GVW would be higher, same truck, same drivetrain. Ford says my rear axles is rated to 7,400lbs...Sterling says 9,550. I've gone up to 235-85/16's, so they're capable of over 12k.
Been that way for 15 years, never a problem.
Chuck & Ruth with 4-legged Molly
2007 Tiffin Allegro 30DA
2011 Ford Ranger
1987 HD FLHTP
Highway Runner
Atlanta, Ga.
Posted: 08/05/21 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
Yep… I weighed mine the other day. 60 lbs below GVWR.
I feel good about it.
2015 Eagle Cap 1165
2016 F-350 Lariat 4x4, 6.2 Boss Dually, 4.30 Axle
Air Lifter 7500 XL w Rancho 9000s & Torklift Stable Loads
ticki2
NH
Posted: 08/05/21 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
Not aimed at anyone n particular but the rational concerning weights sometimes baffles me . So if you put G rated 19.5 wheels and tires on your 1500 series truck you are good for 16000# gvw , wow .
'68 Avion C-11
'02 GMC DRW D/A flatbed
jimh425
Western MT
Posted: 08/05/21 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
I don’t think anyone says that. First, it does nothing for the GVWR. I think that’s what you meant not GVW.
Many SRW rear axles are rated at over 9000 lbs which you’ll never hit with stock tires. Adding F/G rated 19.5s on can bring your tires up to that rating assuming they are aired at the correct inflation which will in effect give you room on the rear axle weight but also won’t raise the RAWR because that’s a number the manufacturer controls as well.
specta
utah
Posted: 08/05/21 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
This morning,
Front rating, 4400 - actual weight 3620
Rear rating, 6200 - actual weight 6980
Something in the rear is really heavy. LOL
Here's my first camper that I bought in 2016, a 9' 1996 Skyline Week Ender.
I weighed the truck on my way to pick up the camper and again on my way home with the camper. This was the day I bought it.
The tag on it says that in "standard" form it weighs close to 3000 lbs.
Extended cabover, microwave, electric jacks and what ever else wasn't standard it weighed 3760 lbs pretty much dry. 760 lbs in accessories.
Only being 9' it the weight was more evenly distributed front to rear.
I don't recall ever weighing it loaded headed camping.
Here's my 1995 Lance the day I bought it. Again I weighed the truck on my way to get the camper and again on my way home with the camper.
The sticker on my Lance says its max weight is 3234 lbs with 40 gal FW, 43 lbs LP and I can't make out how much weight in food in the refrigerator.
On the scale with some water and some LP it weighed 3260 lbs.
Loaded for camping its weighed 3960 lbs including the built in generator.
Kind of surprising that my 11'3" camper weights 500 pounds less than my 9' camper.
I comfortable with the way things have worked out.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
Kayteg1
California > Nevada
Posted: 08/05/21 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
They had better (heavier) wood back in 1996
It also look like Skyline is taller?
specta
utah
Posted: 08/05/21 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
My Lance is one year older than my Skyline.
Supercharged111
Colorado Springs, CO
Posted: 08/05/21 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
I just identify as not being overweight. Fat shaming a truck should be taboo these days too.
2007 Lance 1131
1997 GMC K3500 crew cab supercharged dually
specta
utah
Posted: 08/05/21 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
LOL
And my truck identifies itself as a 1-ton dually.
