RV.Net Open Roads Forum: Fifth-Wheels: Replacing front landing gear box and motor.
 > Replacing front landing gear box and motor.
shadows4
Kansas City, Mo
Posted: 08/05/21 09:38am Link  |  Quote  |  Print  |  Notify Moderator
Hey guys, got a question. I am replacing my front landing gear box and motor. The 5er is in my driveway and is raised fairly high. I have a sloping drive and I can walk under the pin. I am 5'7". My question is can I remove the motor and gear box without lowering the trailer? Will it fall if I pull those two item? I would like to do this without hooking to the truck if possible. Thanks, John.
2003 4X4 F350,CC,SB,Lariat,7.3L diesel, 214,000 miles
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
Tyler0215
Iowa
Posted: 08/05/21 10:14am Link  |  Quote  |  Print  |  Notify Moderator
What do you think is holding the fiver up? Of course it will fall. Hook up the truck and support and chock very well so the truck and trailer does't move.
Lantley
Ellicott City, Maryland
Posted: 08/05/21 10:29am Link  |  Quote  |  Print  |  Notify Moderator
You can possibly use a heavy duty jack stand to support trailer inlieu of truck. But you will need to support trailer somehow
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
jdc1
Rescue, Ca
Posted: 08/05/21 11:56am Link  |  Quote  |  Print  |  Notify Moderator
On a slope, I would skip the jackstands.....use the truck.
Njmurvin
Simi Valley
Posted: 08/05/21 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
From etrailer.com:
Question - "Do you need to place a support jack under trailer before you remove gearbox ? My tube on the gear side did not retract the same amount as the non gearbox side. I suspect gearbox may need replaced."
Expert Reply - "If you can level your trailer it is not necessary to add an additional support jack before removing your gearbox. The gearbox turns the screw that activates the jack, but it also has a fail safe that does not allow the jack to drop if the gearbox is removed. In the case you are not able to level your trailer, you will need an additional support jack."
All that said, I'm paranoid about being crushed. So, I'd hook it up to my truck for peace of mind.
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
fj12ryder
Platte City, MO
Posted: 08/05/21 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
These front jacks are a screw-type setup and will not fall if you pull the motor and gearbox. The motor and gearbox turn a threaded rod with runs in the matching threaded leg. That is what supports the trailer.
JMO, but depending on how heavy your trailer is, you might consider going to a two motor system like the Bulldog legs. That's what I put on our Fuzion and it works so much better than a single motor setup. Plus a side benefit is being able to move the legs independently to allow for uneven ground.
Howard and Peggy
"Don't Panic"
fj12ryder
Platte City, MO
Posted: 08/05/21 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
Not true.
camperfamily
New Jersey
Posted: 08/05/21 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Having replaced landing gear 3x now I doubt the jacks will allow the trailer to drop with just removing the gearbox and motor. However, in this scenario where your under the front of the trailer I would either hitch to the truck or build up cribbing immediately behind the landing gear under the frame. Each time I've done this I've hitched up. Close quarters but very doable.
2011 Cougar 322QBS
2007 Pilgrim 278BHSS (Sold)
2013 F350 CC LB 6.7
2002 F350 CC LB PS (Retired)
B&W Companion Hitch
minnow
Upstate South Carolina
Posted: 08/07/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
https://www.youtube.com/watch?v=fM5xof0at94
Tutorial but please use a jack stand.
Veebyes
Posted: 08/07/21 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Been there. Done that more than a few times.
No need to remove leg if only removing the motor. The leg is not going to collapse.
Removing the leg is another matter. The motor comes off first. Best to stay on the truck for safety. If not, transfer weight onto blocks under the frame before removing anything.é
2007 Alpenlite 34RLR
