RV.Net Open Roads Forum: Fifth-Wheels: Replacing front landing gear box and motor.
 > Replacing front landing gear box and motor.
bucky
Raleigh metro
Posted: 08/08/21 04:01am Link  |  Quote  |  Print  |  Notify Moderator
I'm thinking I'd move the rig to a level parking lot somewhere before tempting gravity.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
Memphisdoug
Memphis, Michigan
Posted: 08/13/21 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
Did this exact thing last year. No worries about the trailer falling when removing the motor and gearbox. Easy swap out.
2006 Silverado 3500 Crew Cab
2006 Crossroads Paradise Pointe 36RL
cummins2014
Utah
Posted: 08/14/21 07:11am Link  |  Quote  |  Print  |  Notify Moderator
fj12ryder wrote:
Tyler0215 wrote:
What do you think is holding the fiver up? Of course it will fall. Hook up the truck and support and chock very well so the truck and trailer does't move.
Not true.
I believe a few misunderstood the OP. He's replacing the gear box, and motor, those landing gear legs won't move, unless the motor turns. He said he's on a slope, so I am sure he has it chocked well.
I have worked on the gear box ,and motor more then once never had to do anything with supporting the trailer, as said those landing legs can't go anywhere if the motor is removed from the drive side .
shadows4
Kansas City, Mo
Posted: 09/09/21 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
Hey guys, just wanted to touch base you all. I did change out the gear box and motor and the fiver didn't fall. It turned out to be the switch was bad. Glad I did it myself as now I have a spare gear box and motor. Thanks, for all the replies.
John
2003 4X4 F350,CC,SB,Lariat,7.3L diesel, 214,000 miles
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
laknox
Arizona
Posted: 09/13/21 10:04am Link  |  Quote  |  Print  |  Notify Moderator
John
Cool! Glad it worked out for you, and thanks for the update!
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
Veebyes
Posted: 09/13/21 10:38am Link  |  Quote  |  Print  |  Notify Moderator
jdc1 wrote:
On a slope, I would skip the jackstands.....use the truck.
Having removed legs myself more than once or twice & also having the trailer slip, the safest way to remove a leg is to do it on level ground & hooked to the truck.
Transferring weight to stands or blocks of wood is fine however the truck is a fail safe insurance device should something slip. It won't drop far.
2007 Alpenlite 34RLR
Lantley
Ellicott City, Maryland
Posted: 09/13/21 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
I agree attached to the truck is foolproof and is ultimately the safest method.
However the truck is in the way and limts my access to the leg.
I don't believe I can raise the front hatch attached to the truck either.
while I agree using the truck is the safest method but it also makes the job more difficult.
On flat ground heavy duty jackstands are safe enough for me.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
