RV.Net Open Roads Forum: Truck Campers: ATV Muffler on Genset?
 > ATV Muffler on Genset?
adamis
Northern California
Posted: 08/05/21 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone added an ATV muffler to the onboard generator? Noticed mine is just a straight pipe. Curious that they didn't put any muffler at all on it. Wondering how effective it might be to add one.
1999 F350 Dually with 7.3 Diesel
2000 Bigfoot 10.6 Camper
n0arp
FT
Posted: 08/05/21 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
I put a tractor muffler on mine. It doesn't really reduce the volume, but changes the sound and gets rid of some of the more annoying notes.
I had more overall success lining the generator compartment with Dynamat, creating a floor for the generator compartment out of stall mat, using the leftover stall mat to make better mounts, and a few other little things.
Despite all the things, it's still annoying and still loud. If I ran it very often, I'd consider replacing it with the new inverter model. That being said, it's way better than when I bought it.
2021 Ram 5500 Limited 84CA Cummins 4x4 w/ flatbed
2020 Jeep Wrangler Unlimited Rubicon 2.0T (follow or TC toad)
2015 Keystone Alpine 3730FB 2925W/22.8kWh, 30K multi-split
2016 Arctic Fox 1140 WB 1800W/11.4kWh
bgum
South Louisiana
Posted: 08/05/21 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
As has been reported exhaust is only about 1/2 of the noise made by a generator.
Fisherman
Angus, Ontario, Canada
Posted: 08/05/21 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
I would suggest if you try that idea, go with the small muffler for a 4 stroke. Most common generators are about 3-6 HP where even the small ATV's run 25 HP and up. I would think using the appropriate size to the motor makes a difference.
SDcampowneroperator
South Dakota
Posted: 08/05/21 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
We have a John Deere 590 xuv SxS that to us has very loud exhast Its hard to talk to one another . We want to be quiet riding in the woods, not proclaim our presence. . It isnt a performance machine, we are disappointed that JD engineered such a fine machine but failed to address the noise level. JD had no options for a quiet muffler.
Researching quiet aftermarket exhaust for a 600cc motor found no options that I even in my welding shop could modify to fit.
It seems quiet is the name of the game for gennys, loud for toys. Why?
jimh425
Western MT
Posted: 08/05/21 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
I changed to synthetic in my Onan generator after noticing my diesel got quieter with a change to synthetic. Both were noticably quieter. It actually makes sense when you read that the majority of the noise is mechanical. YMMV.
bighatnohorse
Gig Harbor - Cave Creek
Posted: 08/06/21 08:25am Link  |  Quote  |  Print  |  Notify Moderator
Onan used to make a muffler kit for earlier models:
https://yakimagenerator.com/product/onan-kvd-muffler-kit-541-0618/
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“The best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
mr_andyj
Georgia
Posted: 08/06/21 08:56am Link  |  Quote  |  Print  |  Notify Moderator
The other half of the noise is usually the valves/mechanical noise...
You can do a valve adjustment and bring it back to spec and that might help slightly, but that noise will always be there.
Mufflers are tuned to the engine they serve, so you would have to try different ones.
I had an old Onan from 1970 that had a car-looking muffler on it, not unlike the above post. It did lower the noise, mostly the high frequencies, but it was still loud. It was a big one-cycender banger, but ran at 1,800 rpm so was quieter than your 3,600 rpm gen.
sd1209
Elko, Nv & SoCal
Posted: 08/06/21 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Onan makes a resonator....Goes inline with the exhaust....About $40 as I recall......There are YouTube video's as well comparing noise levels with/without the resonator......
I put one on my Onan 2500 LP and it did make a difference..Not much but a difference..Seemed to change the frequency of the noise and made it almost tolerable......Noise from the generator is my biggest complaint ......
Steve and Liz
Elko, Nv and San Diego, Ca
2017 Lance 1172
2016 F350 dually
2010 Jeep Wrangler
mellow
Salisbury, MD
Posted: 08/06/21 09:50am Link  |  Quote  |  Print  |  Notify Moderator
From what I remember putting a resonator or a muffler on the exhaust adds backpressure which adds heat and load to the engine which Onan says is not a wise thing to do on the 2500 series.
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
