RV.Net Open Roads Forum: Fifth-Wheels: Residential Stove/Oven
 > Residential Stove/Oven
2halfs
CA.
Posted: 08/05/21 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
My husband and I are preparing to sell our travel trailer.
We are looking to purchase a 5th Wheel.
We have not settled on a manufacture as of yet. We plan on to purchase something that is no more then 4 years old to new....depending on features, size and of course $'s.
My sister and brother-in-law have recently bought a 2021 Grand Design 5th Wheel.
The heads up from my sister is to make sure we do not purchase a unit with a "residential Stove/oven".
Please share your intake, experience, knowledge on this.
Thank you,
Denise
* This post was edited 08/05/21 08:40pm by 2halfs *
Happiness in an RV is a Full Tank of Gas,
and an Empty Holding Tank!
Tom_M
New Hope, MN
Posted: 08/06/21 04:26am Link  |  Quote  |  Print  |  Notify Moderator
I have a small 4 burner residential cooktop, no oven. I have two issues, the burner igniter operates on 120 volt only and the burner tops will dance around if not secured with bungee cords. It works much better than the cheap Suburban that it replaced.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 1978 VW Bug convertible
Minneapolis, MN
way2roll
Wilmington NC
Posted: 08/06/21 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Did they say why? Ours has a residential stove and it's a far cry better than the small rv one's we've had in previous RV's. I can't think of a single con to a residential unit over an RV specific one.
NRALIFR
Truck Camping Out West
Posted: 08/06/21 06:49am Link  |  Quote  |  Print  |  Notify Moderator
I wonder what is actually meant by “residential Stove/oven"?
There are gas residential stove/ovens that can be setup to use either natural gas, or propane. I don’t see a problem there.
There are of course electric residential stove/ovens that need 240v AC. That would be a problem.
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450 ‘Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam types………..Let’s Go Brandon!!!
JTrac
Oklahoma
Posted: 08/06/21 06:57am Link  |  Quote  |  Print  |  Notify Moderator
I'm assuming your sister is talking about the Insignia residential style range that some fifth wheels are now making a standard feature. We have one in our Pinnacle and have not found a down side to it. It cooks and bakes much better than any rv type oven we have ever owned. The temps in the rv ovens were very difficult to regulate which resulted in burned biscuit bottoms. We haven't used the Insignia oven a bunch but it seems to be fairly accurate with the temp settings. I would ask for more details as to what she doesn't like about it.
We tend to use the convection feature on our microwave as much as possible as it does not generate as much heat as the oven does, especially in hot weather when we are trying to help the a/c's keep us cool.
JimT
2020 Jayco Pinnacle 32RLTS, 2020 Ford F350, Platinum, 6.7 diesel, 4X4, CCLB, SRW, 12,400 GVWR
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 08/06/21 07:50am Link  |  Quote  |  Print  |  Notify Moderator
If you have the correct pots and pans, drop the gas oven/cook top. We have an Induction Cook Top and use the Convection side of the Micro for all Baking.
Even did a small Prime Rib at New Years and it came out perfect.
Much, much less heat generation inside.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Second Chance
Wherever...
Posted: 08/06/21 07:51am Link  |  Quote  |  Print  |  Notify Moderator
They're probably referring to the Insignia ovens (and cooktops) that Grand Design moved to a year or two ago. There have been issues with keeping the oven lit. It's due to low gas flow and Insignia has come up with a fix for it. Our 2020 GD Solitude came with a Furrion oven and cooktop. The cooktop is great; the oven won't stay within 75 degrees of where it's set. We've not used the ovens in either of our 5th wheels, anyway - we use the convection oven that's part of the microwave and use the lower oven for storing pots and pans.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Whiskey River
Pittsburgh, Pa
Posted: 08/06/21 08:02am Link  |  Quote  |  Print  |  Notify Moderator
Tom_M... I think if you unscrew the top of your igniter or clicker to light the burners, you will find a AA battery. It will light the burner if no plug in is available. At least that is what I have, but I have an oven as well as burners on top....
2halfs
CA.
Posted: 08/06/21 08:14am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all for the input.
I will be asking my sister exactly why she does not recommend the residential style of stove/oven cooking.
I do suspect that it may be due to the fact that you are limited to only use it if hooked up to electrical.
I know that they like to do both style of camping....full hook up and dry camping.
I will be asking her for more information.
Denise
Tom_M
New Hope, MN
Posted: 08/09/21 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
The igniter is strictly 120volt. This is a residential cooktop. To light a burner you turn the knob for the burner then press it in for a few seconds to activate the igniter.
