RV.Net Open Roads Forum: Tech Issues: 2016 flagstaff micro-lite propane fridge
 > 2016 flagstaff micro-lite propane fridge
nmhuntr
Las Cruces, NM
Posted: 08/05/21 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
I am looking into buying a used 2016 TT and the guy says the unit fridge runs fine on power but cuts off if running on propane for very long. Has anyone had a similar issue? I am trying to figure out what I may be up against should I decide to buy it.
Thanks
2005 Fleetwood Pioneer ASV 180FK
2018 Ford F-150 3.5 EB 3.55s
Bumpyroad
Virginia
Posted: 08/06/21 06:08am Link  |  Quote  |  Print  |  Notify Moderator
if it was an easy/cheap fix, he would have fixed it.
bumpy
Old Days
Colorado
Posted: 08/06/21 06:25am Link  |  Quote  |  Print  |  Notify Moderator
Take $1500.00 of the asking price just in case the frig is shot.
mr_andyj
Georgia
Posted: 08/06/21 09:13am Link  |  Quote  |  Print  |  Notify Moderator
could be issue in the propane line. could be regulator. I assume the stove will blow full power on all 3 burners???
Possible the pipe to the fridge is blocked mostly, will build up decent pressure when fridge is off, will burn good on that pressure for a while then flames out. I have heard of pipes being blocked like this and even the oil filling the low places doing this. There is an oil in the propane tanks that can get into the lines...
More likely there is issue on the fridge itself. The thermocouple could have issues, and for a handy guy can be a cheap fix. Burning a flame is not rocket science so whatever the issue it can be fixed. As long as the fridge does work on electric then the fridge is good.
