RV.Net Open Roads Forum: Newbie: it appears tank hoses don't come with new trailer
 > Newbie: it appears tank hoses don't come with new trailer
Near DVNP, California
Posted: 08/06/21 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
Hose support is a good thing to have even if you boondock and only dump every so often.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Posted: 08/06/21 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
Is this like a boxers vs briefs type of thing? LOL
But seriously, what would one possibly use them for if boonie docking?
I mean even when you dump your gray water into the woods, it's a 1 n done shot.
Or do you set up the hose supports when you're dumping your camper at the dump station?[emoticon]
2017 Heartland Torque T29
Terryallan
Foothills NC
Posted: 08/06/21 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
Best thing. Get a sidewinder, and a a pvc pipe cut in half. Lay out the sidewinder. lay the half pipe in it, and lay the hose in that. Makes things really neat, and easy. That way you have a steady drop to the sewer hole, and the hose empties very cleanly.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Sagebrush
Jacksonville AL
Posted: 08/06/21 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
I've bough a few RV units and the dealers put a very simple starter kit in with a couple hoses and some black tank treatment samples. But I didn't dare trying to use the sewer hose. I use the grey and yellow Camco hose from Walmart, comes in 10' sections. I would say you need 20' of slinky stinky in two 10' sections and the sidewinder 20' support. I also highly recommend the clear plastic sewer cap with the handle for the trailer. Lets you know if there is something there to surprise you, mine has a small drain in-case a dump valve leaks on you. You don't make a mess trying to remove the cap with stinky stuff behind it!
mockturtle
AZ
Posted: 08/06/21 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Yep. Get a Rhino.
2015 Tiger Bengal TX 4X4
Chevy 3500HD, 6L V8
Bobbo
Wherever I park
Posted: 08/06/21 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
In 2007 when I bought my first RV, the dealer gave me a cheap hose. It lasted, maybe, a season. I replaced it with a similar hose. Similar results. Finally, I bought a Rhino hose due to recommendations on this board. Actually, I bought two because of my history with hoses. It is now over 10 years later, and I still have not opened the second Rhino hose.
Bobbo and Lin
chovy
Los Gatos, CA
Posted: 08/06/21 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
Wow. Yeah Amazon is out of the rhino flex right now. But I will get
mobeewan
Hampton, Va
Posted: 08/07/21 12:16am Link  |  Quote  |  Print  |  Notify Moderator
For the dump hoses I made 3 hose carriers out of 5x5 pvc fence post. I also got 2 pieces of PVC gutter and cut one into 5 foot lengths. I stack the gutters inside the fence posts with the hoses laying in them.
I rigged a chain to the long gutter at the end to hook over the 3 inch dump outlet on the trailer. I can use it like a trough to hold the dump hose and can add blocks of wood under the gutter to help support it.
One of these days I'll get around to making some metal rods i can stick in the ground that I can hook into holes along the top of the gutter to support it. If I need to I can use the 2 shorter sections stuck under the main 10' section of gutter to lengthen the trough if needed for more hose.
* This post was edited 08/07/21 12:26am by mobeewan *
GrandpaKip
Flat Rock
Posted: 08/07/21 08:50am Link  |  Quote  |  Print  |  Notify Moderator
20’ of Rhino hose, 2 4’ sections of gutter, and a hose support have served us well for several years. The hose and gutters live in a 5x5 vinyl fence post mounted under a cargo rack that carries the tote.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
enblethen
Moses Lake, WA
Posted: 08/07/21 08:53am Link  |  Quote  |  Print  |  Notify Moderator
I would also make a list of what they gave you or didn't for other needed items.
Did they provide adapters for the electrical would or could create issues. Rig needs to be able to plug into a stand 15/20 receptacle, should have adapter to plug into 50 amp receptacle if rig is 30 amp or 30 amp adapter if rig is 50 amp.
Suggests of other supports are good if you have storage for them.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
