RV.Net Open Roads Forum: Truck Campers: Tire Pressure Q
 > Tire Pressure Q
time2roll
Posted: 08/07/21 10:13am Link  |  Quote  |  Print  |  Notify Moderator
TCCamperNoob wrote:
Hi All, I'm new to all this truck camper stuff. I recently went out on the road and had my tires filled to Ford/tire requirments cold (75 rear, 60 (front). All said and good, right? However, on the road my tires got up over the max pressure of 80psi, like 81-82. Is this normal or should I set cold temp lower? I'm using Wildpeal A/T3W tires LT275/70R18. Any advice would be appreciated. TIA
For about any truck camper you will want to run the rear at the sidewall max. Best to get on a scale to compare to the RGAWR and the tire inflation chart. Is that an oversize tire or OEM size?
675w Solar pictures back up
phillyg
SWFL
Posted: 08/07/21 10:34am Link  |  Quote  |  Print  |  Notify Moderator
There's nothing wrong with using max 80psi for your E-rated tires. Set when cold, i.e., not driven on. All tires with get hotter and psi will go up as driven. No worries as that's factored in by tire engineers. The hottest I've ever seen my FW tires is 135 on a hot summer day. If you choose to go with F or G-rated tires, you'd still be limited by your axle rating, and you should first determine if your wheels can take 110psi.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
Kayteg1
California > Nevada
Posted: 08/07/21 11:19am Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
Certainly never below the door sticker.
My 12' long camper was taking about 400 lb from front axle.
After having it weighted, I lowered from recommended sticker value, to tire manufacturer value for actual weight.
Per tire manufacturer, when my empty dually was showing 2800 lb (do I remember it right? ) on rear axle, I should drive with 30 psi.
Obviously for short periods of empty driving I did not play with it, but the results were pretty harsh, regardless Sulastic hangers.
Without the hangers I was afraid to drive empty over street covers.
Posted: 08/07/21 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
Agree, the door sticker is not a good source for proper pressure for the load.
Anyone who is hauling heavy, or even just driving, any vehicle, owes it to themselves to get just a little bit educated about tire load ratings and pressures based on load, driving style, weather and comfort.
Those that can’t, won’t or don’t, is why the mfg puts the door sticker on that basically gives you most or all of your OE trie load capacity or expected load without consideration for any of the above conditions I mentioned.
OP, on your srw truck, unless you’re hauling a lightweight popup camper, anything around 3klbs or above begets max rest pressure in most all common sizes of truck tires.
That pressure is also woefully too high when it comes to driving with no load and even more so in rain or snow.
Bottom line, learn what “your” pressure should be, not the generics mfgs recommendation. Also learn the basics of the ideal gas law. That will help one understand how it’s normal for the pressures to vary with temperature.
2017 Heartland Torque T29
JimK-NY
NY
Posted: 08/07/21 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
BSWS19 wrote:
Setting the pressure at "cold" temperature makes sense to me but, do I need to compensate any in AZ when "cold" tire temps can be 80 to 90 degrees? I usually set mine about 5 psi less than recommended and still see highway temps of 100 to 110 degrees.
I lived a number of years in Phoenix where above 110 on a summer day was frequent. No, do not reduce the tire pressure. In fact consider higher pressure when the temps are high. Tires get really hot on pavement and high starting pressures reduce flex and help with tire life and safety. You probably notice a lot of RVs on the side of the road due to tire issues on hot days. Quite often the reason is low tire pressure.
TCCamperNoob
Posted: 08/09/21 09:32am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the info.
What I learned here:
It may be better to fill my cold rear tires to max pressure of 80 PSI regardless of the door sticker.
Being over max pressure of 80 PSI while hot/driving is fine
My tires are not overheating at 5-8 psi over and even much higher pressure is still ok as long as I did not fill over the max psi while cold.
Some people recommend I get a degree in Tireology.
time2roll
Posted: 08/09/21 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for taking a selected snippet of my statement out of context.
I agree with your reduction of pressure for the specific case you have listed.
TCCamperNoob
Posted: 08/10/21 07:07am Link  |  Quote  |  Print  |  Notify Moderator
LOL You know you asked a good question when a bit of steam occurs in the thread...
Posted: 08/12/21 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Um, there aren’t any LT tires that are over 80psi. Any tires that are 110s are 19.5s or 22.5 for pickup truck applications.
 > Tire Pressure Q
