RV.Net Open Roads Forum: Travel Trailers: New TT Tires
 > New TT Tires
QCMan
Independent Republic of Horry
Posted: 08/06/21 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
Order the Endurance direct from GoodYear and have them delivered to your local GoodYear dealer. I recently went to the local dealer and he said 3 to 4 months for delivery. Went online to GoodYear and they had a discount for each tire and the cost covered mounting and balancing and disposal. The tires were at the local dealer four days later and four were three weeks old and the fifth was four weeks old.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
azdryheat
Tucson, AZ
Posted: 08/06/21 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
Basically stay away from any tire Made In China. Endurance would be my choice.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
deltabravo
Spokane, WA
Posted: 08/06/21 11:22pm Link  |  Quote  |  Print  |  Notify Moderator
Deano_1 wrote:
Goodyear Endurance tires for about $212 each.I’ve used Goodyear Marathons before without any issues, but they no longer make them.
Endurance replace the Marathons.
I run Endurance on two trailers. Northwood and ORV install Endurance at their factories.
I have no issue recommending Endurance.
Just be sure to get all metal valve stems and also have the tires balanced.
Huntindog
Phoenix AZ
Posted: 08/07/21 04:36am Link  |  Quote  |  Print  |  Notify Moderator
No trailers come from the factory with the tires balanced. The manufacturers and many others do not think it is of benefit in a solid axle. I will not enter into that debate here and now. If you choose to have it done, be sure that they use a lug plate to do it. This because most trailer wheels are lug centric, not hub centric. Using the hubcentric method on such a rim is a waste of time and money and could even make the out of balance worse.
Tire shops hate to do it as it takes more time, and a lot of them do not have the lug plates. I have witnessed several times shops not doing when I had requested it. Ask for it, and watch them to make sure they do it.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1380watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
ken56
Tennessee
Posted: 08/07/21 06:09am Link  |  Quote  |  Print  |  Notify Moderator
Go with the Endurance.
Vintage465
Prunedale CA.
Posted: 08/07/21 09:00am Link  |  Quote  |  Print  |  Notify Moderator
I would limit my choices to Goodyear Endurance or Maxxis. Maxxis is the only tire from China I would have any confidence in. Maxxis owns their own factory in China and they have their own people managing from inspection to production and quality control. At the time of my reading an article in Trailer Life magazine, Maxxis was the only Chinese tire able to boast this as all other Chinese tires were contracted and stamped with a brand............that was at the time I read the article 4-6 years ago. But I'd still go with Goodyear if possible. And yes, Endurance replaced Marathons.
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
deltabravo
Spokane, WA
Posted: 08/07/21 09:22am Link  |  Quote  |  Print  |  Notify Moderator
The point of going with all metal valve stems is the rigidity factor when using a TPMS sensor.
If you don't have a trailer TPMS system yet, get one!
My choice for all metal valve stems.
deltabravo
Spokane, WA
Posted: 08/07/21 09:27am Link  |  Quote  |  Print  |  Notify Moderator
Another thing to consider doing is a wheel bearing service. I do that on any trailer I purchase.
profdant139
Posted: 08/07/21 09:33am Link  |  Quote  |  Print  |  Notify Moderator
I have 40,000 miles on my Endurance tires. So far, and so good. [emoticon]
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
propchef
NORCAL
Posted: 08/07/21 11:04am Link  |  Quote  |  Print  |  Notify Moderator
Tires should always be balanced, period. A good shop can dynamically balance the tires.
The reason it isn't always recommended is from a comfort standpoint. The vibrations from an unbalanced tire aren't really felt in the TV unless they're really out. However, an unbalanced tire causes premature, uneven wear and excessive heat.
Tires appear to be a common failure point, but it's the weight, TT suspensions and lack of maintenance that contribute to these failures.
 > New TT Tires
