RV.Net Open Roads Forum: Class A Motorhomes: ALladin tank monitor
 > ALladin tank monitor
Seabass69
Posted: 08/06/21 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
My alladin system seams to be fine, except for the tank monitor. I replaced a sensor on the fresh water and it still shows XXXX for a reading on the tank and raw value on the sensor. I can only assume the monitor module is bad? it has power to the module. what are my options? I would like to get it all work as it should somehow. 2004 holiday rambler sceptor... thanks
Ivylog
Blairsville, GA and WPB, FL.
Posted: 08/07/21 05:51am Link  |  Quote  |  Print  |  Notify Moderator
I believe there is a Sealand sensors conversation that works better.
Sold 04 Dynasty to our son after 14 great years.
Upgraded with a 08 HR Navigator 45’...
dougrainer
Carrolton, Texas
Posted: 08/07/21 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Alladin system when you replace a sending unit you MUST input calculations for it to work. When NEW, Monaco had a calibration sheet in the owners packet that gave the values for your particular model. So, if no sheet, I don't know what you can do. You might try and contac these people. Doug
https://www.silverleafelectronics.com/node/4163
dougrainer
Carrolton, Texas
Posted: 08/07/21 07:59am Link  |  Quote  |  Print  |  Notify Moderator
Page 189 shows the calibration process. Doug
https://www.monacocoach.com/resources/media/manuals/2006_Signature.pdf
dougrainer
Carrolton, Texas
Posted: 08/07/21 08:03am Link  |  Quote  |  Print  |  Notify Moderator
delete
Seabass69
Posted: 08/07/21 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
calibrating is the easy part after watching youtube. but its not registering any value on the sensors, even the new on. I did order a seperate system from seeland for now....
