RV.Net Open Roads Forum: Tech Issues: Replacing 50A Electric Cord
 > Replacing 50A Electric Cord
obiwancanoli
Napa
Posted: 08/07/21 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone replaced the electric cord on their MH, the one you hook up to shore power? Is the cord specific to the MH, or will a generic cord work too? Can it be done easily, or is it something you'd have a service tech do?
enblethen
Moses Lake, WA
Posted: 08/07/21 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Is your cord detachable at the rig?
Fairly easy job in most cases. Some times you can get a 35 foot extension cord, remove the coach end for less dollars then buying parts.
It is hard to find good cable that is flexible. Most cable is 6/4 cable. Many RVs use 6/3 plus # 8 ground to reduce size and weight.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
agesilaus
North Florida
Posted: 08/07/21 10:57am Link  |  Quote  |  Print  |  Notify Moderator
I replaced the 30 amp cord. No big deal, just follow the end of the cord as it goes into the RV and find where it is spliced into the RV electrical. Remove the old cord and splice in a new one. The cords are generic. I had to remove a tail light to get enough room to work in. Just make sure to match the colors.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
wolfe10
Posted: 08/07/21 11:38am Link  |  Quote  |  Print  |  Notify Moderator
It depends on the configuration of your shore power cord.
The male end is standard.
The coach end is where there are differences. Some are hardwired in, some use a receptacle-- there are several different ones.
Tell us what the coach end of your cord looks like.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
pianotuna
Regina, SK, Canada
Posted: 08/07/21 11:56am Link  |  Quote  |  Print  |  Notify Moderator
Roll your own is just fine. You may wish to use wire that is UV protected and flexible at low temperatures.
Regards, Don
Cummins12V98
on the road
Posted: 08/07/21 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
S O cord is what you want.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Posted: 08/07/21 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
From what I have seen in many years of RVing there are basically, depending on how you count 3 or 4 different cords
30 amp direct connect (Common on trailers)
30 amp disconnectable.. These use a twist lock connector we usually call a marinco, though other companies make identical or nearly so (Compatable) inlets and outlets (The outlet is the cord end)
30 amp detachable cords for 50 amp rigs (Rare. I have one)
50 amp detachable They use a different twist lock (3 blades)
NOTE the 3 blades are 4 wires (the forth is around the edge of the connector)
Some use a 50 amp reel cord (Attached) but if the cord is detachable.. Than any 50 amp shore cord you get should work fine.
Jack_Diane_Freedom
Burlington Ontario Canada
Posted: 08/07/21 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
You might want to check out boat cords. They are much lighter and more flexible.
obiwancanoli
Napa
Posted: 08/07/21 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
Why?
rhagfo
Portland, OR
Posted: 08/07/21 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
X2!
I have a 40’ (measured end to end) of 6/4 SOOW cable i coil it into a 3 gallon bucket at 90 degrees or 20 degrees, one of the best investments I have made.
