RV.Net Open Roads Forum: Tech Issues: Question about solar combiner box.
 > Question about solar combiner box.
EMD360
Arvada, CO
Posted: 08/09/21 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
Pianotuna: it’s interesting to note that I’ve read that plain monocrystalline cells perform better under test conditions but recommendations for the best low light panels include both poly and mono types. So a lot to be said for the manufacturing.
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
StirCrazy
Kamloops, BC, Canada
Posted: 08/10/21 09:38am Link  |  Quote  |  Print  |  Notify Moderator
alot has to do with the actuyal design of the panel also. split cell mono panels give better low light preformace than non split cells, 24v panels have better low light preformance than 12V. also how many bypass diods are they using and so on. a mono panel should out preform a poly if they are built to the same specs, its when you start comparing cheep mono to quality poly panels that things get skewed.
basickly poly panels are made from the reject wafers that were suposed to be mono panels, that why they need a larger size for the same output, are less efficent and so on. but weather its a poly or a mono if its sized properly they will both have the same result.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
time2roll
Posted: 08/10/21 11:36am Link  |  Quote  |  Print  |  Notify Moderator
EMD360 wrote:
Except I think I’ll use thicker wire to the controller.
#8 is also readily available.
675w Solar pictures back up
