RV.Net Open Roads Forum: Tech Issues: Removing clear silicone caulk from exterior fiberglass
 > Removing clear silicone caulk from exterior fiberglass
noteven
Turtle Island
Posted: 08/09/21 08:59am Link  |  Quote  |  Print  |  Notify Moderator
I bought a vintage (ok - old) Bigfoot camper that is pretty much in stock condition - as the seller said it hasn't had the Pintrest treatment -
But - the camper has suffered an attack of the Silicone Monster to the exterior - every window, arpeture, access door frame etc has recieved generous globs of clear hardware store variety silicone sealant.
Granted, I think the thing would float - but it does not look that attractive all stuck up with dirt and grime - and my looks standards are not that high...
Anyhoo - I would like to remove the silicone sometime in the future -
Anyone who has done this - what is the best cleaner to remove the silicone residue from the fiberglass gelcoat?
Thanks
Fisherman
Angus, Ontario, Canada
Posted: 08/09/21 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Years ago I used the 3M caulk remover, works like a charm, apply wait about 20 minutes and most peels away or can be removed with a blade. there's also this with a good rating. https://www.homedepot.com/p/Goo-Gone-8-o........ro-Power-Adhesive-Remover-2037/205188154
I never use silicone, only polyurethane caulks. Lasts longer than the RV will, and doesn't get as dirty as silicone.
valhalla360
No paticular place.
Posted: 08/09/21 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Problem with silicone is you can pretty much never get all of it off.
If it's not leaking, I would leave well enough alone.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
gbopp
The Keystone State
Posted: 08/09/21 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
Do a YouTube and/or Google search for removing Silicone caulk.
You'll get several responses.
Mel Stuplich
Wausau, WI
Posted: 08/09/21 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
Apply acetone, white vinegar, isopropyl rubbing alcohol, toluene, or xylene to the silicone caulking. Spray or rub one of the solvents on the silicone caulking to dissolve it and scrape the area with a putty knife or scraper. Pour water on the area, wipe up the area with a rag, and vacuum it when it's dry.
* This post was edited 08/12/21 05:52am by Mel Stuplich *
frankwp
Calgary, AB, Canada
Posted: 08/09/21 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
Silicone sealant has become like a plague on humanity. It's great stuff for certain uses, but there is almost always a better choice when caulking is required. Even when using caulking remover, it's very hard to remove all traces of the ****.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
noteven
Turtle Island
Posted: 08/10/21 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Ya I have done a bit of that. A lot of presenters seem to call every kind of sealant "silicone"
What is gooped all over this unit is the clearish product found in hardware stores called "Silicone Sealant"
The first inch comes off by mechanical means.
I am researching how to remove the residue so I can go back with urethane. Sikaflex 522 UV
noteven
Turtle Island
Posted: 08/10/21 07:22am Link  |  Quote  |  Print  |  Notify Moderator
You should see me lose my mind when I go to remove a motorcycle valve cover and some DIY person has used it and the crumbs start falling in the engine....
noteven
Turtle Island
thanks for the replies so far
theoldwizard1
SE MI
Posted: 08/10/21 08:59am Link  |  Quote  |  Print  |  Notify Moderator
If it is the silicon caulk designed for bath tubs, you have a fight on your hands !
If it is silicon-ized latex caulk it should come off easily.
