RV.Net Open Roads Forum: Grey and Black Water Dumping - Back End Sits Higher
 > Grey and Black Water Dumping - Back End Sits Higher
TCCamperNoob
Posted: 08/09/21 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Hi, My truck camper sits a bit higher in the rear. Truck doesn't squat to level loaded with camper. Will this be a problem for dumping waste water? If so, might need to remove my helper/supersprings.
srschang
Western NY
Posted: 08/09/21 11:33am Link  |  Quote  |  Print  |  Notify Moderator
Depends which direction the outlet comes out of the tank. Most tanks have a molded in downhill to the drain. In the large scheme of things, a gallon left in a tank after you drain doesn't really matter.
2022 Ram 3500 Dually Crewcab Longbed Cummins, 2019 Northstar 12 STC
TCCamperNoob
Posted: 08/09/21 11:46am Link  |  Quote  |  Print  |  Notify Moderator
thanks
Bedlam
PNW
Posted: 08/09/21 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
You can always drive up on blocks with the front wheels if you want better or faster draining at the dump.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE
deltabravo
Spokane, WA
Posted: 08/09/21 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
This is what I do. My truck also sits tail high.
TCCamperNoob
Posted: 08/10/21 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Thanks. Can you all recommend a light set of blocks for this amount of weight?
Geo*Boy
Unknown
Posted: 08/10/21 07:15am Link  |  Quote  |  Print  |  Notify Moderator
Lynx Levelers.
MORSNOW
Mountain Home, ID
Posted: 08/10/21 08:15am Link  |  Quote  |  Print  |  Notify Moderator
I always carry various lengths of 2x6's for under my tires, under the jack bases, and can be split with a hatchet for starting the campfire. They are lightweight and can fit in many small spaces around the camper and truck.
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD
7,220# Truck/10,400# Camper Fully Loaded
jaycocreek
Idaho
Posted: 08/10/21 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Lifepo4-380ah/Lithium NMC-140ah/Solar-400 watts/Wagan & Giandel PSW/Engel & Iceco 3-1 compressor fridge freezer/5K Window AC/Honda 2K
deltabravo
Spokane, WA
Posted: 08/10/21 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
Any style of stackable RV leveling blocks will work. I use then or pieces of 2x8
