RV.Net Open Roads Forum: Fifth-Wheels: 5th wheel Hitch recommendations
 > 5th wheel Hitch recommendations
MFL
Midwest
Posted: 08/10/21 04:22am Link  |  Quote  |  Print  |  Notify Moderator
Any good quality standard hitch, designed for direct fit to pucks will work. I'd suggest a 16K rated, or higher rated hitch. A 16K rated hitch will handle any FW your truck is capable of carrying, or pulling.
The B&W 3600 is a good hitch for the OEM Ram puck system, and looks similar to the Ford version pictured.
Single point attachment hitches are normally not recommended with the rotating pin boxes. These are the ones that attach to the center ball.
Jerry
southernsky
Ponchatoula La.
Posted: 08/10/21 06:10am Link  |  Quote  |  Print  |  Notify Moderator
Short box I would go with a auto slider. I've had 3 mega cabs and used the Pullrite Auto Slide. Yes it is heavy but you never have to worry about hitting your cab in a turn. No matter how much room you have, there will be a time when the cards will be right and it will happen. Just piece of mind.
2019 Ram 3500 Laramie DRW Crew Cab 6.7 H.O. CTD 4X4
2016 Grand Design Solitude 369RL 5th Airborne
ReneeG
Meridian, Idaho
Posted: 08/10/21 07:08am Link  |  Quote  |  Print  |  Notify Moderator
We have a Hensley TrailerSaver BD3 and have since we got our FW back in 2010. We travel backroads and forest service roads to boondock, so this hitch has done us well.
**Note: we used to have this hitch in a short bed with a slider adaptor. Never needed the adaptor.
* This post was edited 08/11/21 02:59pm by ReneeG *
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
cummins2014
Utah
Posted: 08/10/21 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
Andersen hitch all the way , with your setup it’s a no brainer .Quietest , lightest hitch on the market . Ideal for short beds , no need for those manual or automatic sliding hitches
* This post was edited 08/11/21 12:48pm by cummins2014 *
GMH
Canada
Posted: 08/10/21 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
cummins2014 wrote:
Andersen hitch all the way , with your setup it’s a no brainer .Quietest , lightest hitch on the market . Ideal for short beds , no need for those heavy manual or automatic sliding hitches .
Correct me if I’m wrong, but I think the Turning point swivel pin box that the OP’s trailer is equipped with requires a conventional hitch?
* This post was edited 08/11/21 06:22pm by GMH *
Ron3rd
Upland, CA USA
Posted: 08/10/21 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
X2 So thankful I did not go with the slider.
To the OP do your research and decide for yourself.
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
Ron3rd
Upland, CA USA
Posted: 08/10/21 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
GMH wrote:
Correct me if I’m wrong, but I think the Turning point swivel pin box that the OP’s trailer has requires a conventional hitch?
You could be correct. The Andersen does not work with some pinboxes
The Andersen site would have that information
MNRon
Tennessee
Posted: 08/10/21 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
Strongly recommend you consider an autoslider. I’ve used the Pullrite for 7+ years and am very happy with it. It is heavy, and isn’t cheap, but it WORKS. I can’t tell you the number of times I’ve turned tight (going forward or backwards) and watched it just move the trailer out of the way as it glided past the rear corner of my cab. Nor can I tell you the number of shortbed users I’ve seen than have banged up the corner of their cab or punched out the rear window - 2 just in the last week
Ron & Pat
2013 Silverado 3500 Duramax SRW
2019 VanLeigh Vilano 320 GK
cpaulsen
Oregon
Posted: 08/11/21 03:50am Link  |  Quote  |  Print  |  Notify Moderator
Pullrite Superglide here. Used it for the last 5 years with no problems on my shot bed Ford
cpaulsen
GMH
Canada
Posted: 08/11/21 05:49am Link  |  Quote  |  Print  |  Notify Moderator
FYI: Lippert clearly states that the hitch manufacturer should be consulted to establish compatibility with their “Turning Point swivel pin box”.
Quote: “Failure to consult with hitch manufacturer to verify compatibility may result in death, serious personal injury or severe product and/or property damage.”
https://lci-support-doc.s3.amazonaws.com/manuals/towing/ccd-0001724.pdf
* This post was last edited 08/11/21 06:25pm by GMH *   View edit history
