RV.Net Open Roads Forum: Fifth-Wheels: 5th wheel Hitch recommendations
 > 5th wheel Hitch recommendations
jaycocamprs
Ringgold Georgia
Posted: 08/11/21 06:52am Link  |  Quote  |  Print  |  Notify Moderator
The Turning point swivel pin box doesn't need a sliding hitch. The pivot point is at the trailer end, they use a key behind the kingpin much like a Superglide. B&W also recommends the puck mount system, not the single point Companion. The swivel can be locked out if not needed
The OP just needs a hitch to fit his truck. I'd recommend the B&W RVK3600. I got my B&W from Etrailer. They aren't the cheapest hitch, but I don't think you'll find one better made
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
Cummins12V98
on the road
Posted: 08/11/21 09:51am Link  |  Quote  |  Print  |  Notify Moderator
All these compromises because of a short bed instead of a no compromise LongBed.
Friends stayed at our place that have a SB MegaCab and PullRite Auto slide. I looked the hitch over and it looks to be of very high US Made quality. Only real negative I see is he couldn't back into hitch at an angle that would have allowed him to pull straight out.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
cummins2014
Utah
Posted: 08/11/21 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
GMH wrote:
cummins2014 wrote:
Andersen hitch all the way , with your setup it’s a no brainer .Quietest , lightest hitch on the market . Ideal for short beds , no need for those heavy manual or automatic sliding hitches .
Correct me if I’m wrong, but I think the Turning point swivel pin box that the OP’s trailer has requires a conventional hitch?
That’s possible , I missed his post on the pin box. Plus him having a 5.5 bed instead of the 6.4. Sounds like just a fixed hitch with that weight , and pin box ?
GMH
Canada
Posted: 08/11/21 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
The main reason I chose B&W over Curt is that the B&W is made in the USA. Curt 5th wheel hitches are made in China.
Cummins12V98
on the road
Posted: 08/11/21 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
RIGHT ON BROTHER!!!!!!!
To be clear their tow behind receiver hitches are US Made.
Crabbypatty
Long Island, New York
Posted: 08/12/21 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
We have the Pullrite Slider. Works perfectly pulling a 37' with an F250 Short Bed. Can take the rails out as well so you have a flat bed if need be when not in use. 3 Years no issues.
John, Lisa & Tara">">">
2015 F250 4x4 6.2L 6 spd 3.73s, CC Short Bed, Pullrite Slide 2700, 648 Wts Solar, 4 T-125s, 2000 Watt Xantrax Inverter, Trimetric 2030 Meter, LED Lights, Hawkings Smart Repeater, Wilson Extreme Cellular Repeater, Beer, Ribs, Smoker
