RV.Net Open Roads Forum: Class A Motorhomes: flexsteel RV electric captain chair
 > flexsteel RV electric captain chair
Big Jimmy
Livermore
Posted: 08/09/21 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2011 tiffin with 6 way electronic captain chairs, I'm removing the rv captain chairs (only the chair) my question is does the 6 way hand control on the chair have a big plug to be removed on the inside? thanks
Sandia Man
Rio Rancho, NM
Posted: 08/09/21 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
Just had to remove driver side flexsteel chair on our Monaco to work on some wiring under the dash, plug is about an inch square more or less, easy to unlatch and snap back together. Although I didn't give much thought to the size of the plug when removing or reinstalling our 6 way captains chair, it was relatively small compared to other plugs that abound the breadth of our coach.
hotjag1
Lake Chelan, Wa/Lake Havasu, Az.
Posted: 08/09/21 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
On our Tiffin in the signature, the seats(if I recall) have a 3 or 4 wire harness with a plug disconnect that is right underneath the seat beside the swivel base. Easy disconnect on ours.
hotjag1
2003 40' Allegro Bus, 3 slides, 400hp 8.9 liter ISL Cummins
2000 24' Dynamax Isata
Big Jimmy
Livermore
Posted: 08/09/21 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the feed back, I’m not taking out the base so I need to unplug the electrical connector from the outside hand control, large style plug , same size as the hand control, 3-4” long 1-2 wide.
dougrainer
Carrolton, Texas
Posted: 08/09/21 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Just remove the 2 screws that hold the 6 way switch in place. It will pull out enough to remove the backside quick release plug. Doug
PS, you still have to do everything you asked for in a previous post
Big Jimmy
Livermore
Posted: 08/09/21 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you Doug
