RV.Net Open Roads Forum: Class A Motorhomes: How to Remove Convec/Microwave?
 > How to Remove Convec/Microwave?
TC&Z
Posted: 08/09/21 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2007 Winn Voyage 38J. The convection/microwave has stopped working. The microwave, the convection and the turntable don't work. The fan, clock and light do. Anyone know how to remove the unit? What steps are involved? There are no visible screws in the floor of the cabinet above the unit. And the cabinet is nailed panels, no screws.
Thanks....
TC&Z
2007 Winn Voyage 38J, gas 8.1L engine
2018 Jeep Cherokee flat tow
CA Traveler
The Western States
Posted: 08/09/21 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
One method is a back plate secured to the wall that the rear bottom of the MW rests on with bolts on the bottom front corners that angle up to the top of the baseplate. Covers have to be removed to expose the bolts.
2014 Grand Cherokee Overland
Bob
CA Traveler
The Western States
Posted: 08/09/21 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
Also the cabinets might have false floor or side panels that have to be removed.
RLS7201
Posted: 08/09/21 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
Sometimes there is a vent over the top of the microwave. Figure out how to remove the vent panel and you may then figure out how to unsecure the MW.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
rgatijnet1
Posted: 08/09/21 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Do an online search of the brand and model to get to the manual. It should tell you everything you need to know.
johnhicks
Wandering below the Gnat Line
Posted: 08/09/21 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
My High Pointe just rested on a board and was secured by six screws in the trim ring. Just remove the screws and pull.
-jbh-
ArchHoagland
Clovis, CA, USA
Posted: 08/09/21 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
What brand and model microwave is it?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Scottiemom
Posted: 08/10/21 06:14am Link  |  Quote  |  Print  |  Notify Moderator
My husband successfully repaired my Sharp convection/microwave on 2 different occasions. He went to YouTube and found videos that showed what he needed to know. He didn't have to remove the oven either time, but found out how to access what he needed. I'm sure you can find one that shows removing it as well.
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
2022 Honda Odyssey
2011 Mazda Miata MX-5
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
Where are we?
crawford
Dandridge Tenn.
Posted: 08/10/21 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
check u tube for great videos there
Change from a c class to a A class Georgetown 07 triple slide
johnhicks
Posted: 08/10/21 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
BTW, the second HIgh Pointe lasted about a week.
