RV.Net Open Roads Forum: Truck Campers: Roof concern?
 > Roof concern?
Geewizard
WA
Posted: 08/10/21 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
The EPDM (I think it is EPDM) roof on my 2004 Outfitter TC is coming unglued from whatever is underneath it. I see several areas that are lifting up. None are raised more than 1/4" but they show up. I have no signs of leakage.
Should I be concerned? Can I or should I do anything about it?
Looks very similar to this:
2021 Winnebago Micro Minnie 1708FB
2014 Toyota Tundra Double Cab
300W solar, MPPT controller, LED lights
Xantrex Freedom X Inverter 3000W
2 Fullriver 105AH AGM batteries
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
d3500ram
Colorado
Posted: 08/10/21 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
I'm sure others will chime in....but,
I think I would be concerned... if it is losing adhesion in partial areas it might continue to do so over time.
Has anyone else ever seen a TC going down the road where the roof material in the front is ballooning up as it travels? I have seen it perhaps twice. Not saying that the OP's will do the same or is doing this currently, but it might have the potential to do so.
JMHO.
valhalla360
No paticular place.
Posted: 08/10/21 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Is this a new issue? If yes, it's certainly cause for concern.
And yes, I've seen the roof of an RV blown up like a balloon going down the highway.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
mellow
Salisbury, MD
Posted: 08/10/21 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
The adhesive has given up, it should not leak but with time will get worse. Only way to remedy it would be to pull it up and put new adhesive down if it doesn't pull up the luon as you pull it away, in that case you would need to get a new sheet of epdm and put down a new roof. It isn't that bad of a job to do but once you open the can of worms you might see rot on the roof that needs fixing.
This is my old camper I had to redo the roof on to give you an idea: https://imgur.com/a/RriBM
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
Posted: 08/10/21 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
Aside, that is the cleanest roof I've ever seen! Bravo!
No experience, but I'd just keep an eye on it and if it gets worse, some judiciously placed staples with a dab of goo over them to keep waterproof would be my plan of attack.
2017 Heartland Torque T29
anutami
Ramona
Posted: 08/10/21 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
Here is what happened to mine. Keep in mind the wind will cause havoc. Not a fun repair!!
Click link to my repair
2001 Ford F350 LB Diesel 4x4 CrewCab Stick
2015 Wolf Creek 850 Thermal Pane Windows, Oven, Reinforced Anchor Bolts, 200w Solar, Torklift Tie Downs, Fastguns, Stableloads
JIMNLIN
Oklahoma
Posted: 08/10/21 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
the roof on my 1997 31' 10" 5th wheel rv trailer has looked like that in spots since new.
I do a twice a year roof check for blisters or tears or holes in the membrane....sealant cracks...cracked or broken roof jacks and other fixtures. Just keep a eye on it but I sure wouldn't add any more holes the roof for more places for water intrusion.
Kayteg1
California > Nevada
Posted: 08/10/21 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Very seldom roofs do spontaneous ungluing, so I would suspect small leak somewhere.
Now if the leak is due to gap up front, that will suck the air at speeds and create balloon.
I would cut the wrinkles and glue them flat with urethane coulking.
That I would apply Henry $50/gallon roofing sealer on top of everything.
deltabravo
Spokane, WA
Posted: 08/10/21 10:25pm Link  |  Quote  |  Print  |  Notify Moderator
I've seen several 5th wheels with a big "roof membrane balloon"
d3500ram
Colorado
Posted: 08/10/21 10:46pm Link  |  Quote  |  Print  |  Notify Moderator
I often wonder if the owners know (knew) of it.
 > Roof concern?
