RV.Net Open Roads Forum: Truck Campers: Roof concern?
 > Roof concern?
NamMedevac 70
Reno
Posted: 08/11/21 01:09am Link  |  Quote  |  Print  |  Notify Moderator
Yes keep a close eye on it and take occasional photos with your cell phone to see if it is getting worse. See no need for drastic action at this point but make sure no gaps or teares around the roof edges and double check the edge caulking that it is still good condition. I had a few of those on my roof for years with no adverse effects but I also recoated by roof with fresh EDPM once a year. It was fun in early morning cool hours. Cheers
NamMedevac 70
Reno
Posted: 08/11/21 06:44am Link  |  Quote  |  Print  |  Notify Moderator
I have passed a few of these ballooning roofs traveling in opposite direction and glad I wasn't behind them going same way.
Joe417
AL
Posted: 08/24/21 11:06am Link  |  Quote  |  Print  |  Notify Moderator
Our 2001 Jayco has had a few of those since new. It hasn't caused any issue and hasn't gotten any worse.
I have seen RVs traveling down the road blown up like others have mentioned. I would guess they had some type of water damage to have the adhesive let go completely.
I would check to see if it is looser than the wrinkles in the picture and check for cracks in the caulk.
If it isn't any looser than what the picture shows, I wouldn't worry but would keep a check on it until sure it isn't a water leak.
It's in a place that can be re-glued. Just a lot of caulk and putty to remove.
Joe & Evelyn
Hemi Joel
Minnesota
Posted: 08/28/21 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
It should not balloon or have enough loose membrane to lift of flap. It's just a matter of time until repair or replacement is needed.
FWIW, I am a commercial/industrial roofing contractor. We do mostly EPDM rubber and some TPO roofs, I build them to last 30+ years. If I did my roofs to the same low standards as the RV industry, I'd be in jail or bankruptcy court.
2018 Eagle Cap 1163 triple slide on a 93 Dodge D350 Cummins, DTT 89 torque converter, big turbo, 3 extra main leafs, Rancho 9000s rear, Monroe gas magnums front, upper overloads removed, home made stableloads, bags.
deltabravo
Spokane, WA
Posted: 08/29/21 07:14am Link  |  Quote  |  Print  |  Notify Moderator
d3500ram wrote:
Has anyone else ever seen a TC going down the road where the roof material in the front is ballooning up as it travels?
On a TC no, in a giant 5th wheel, yes, at least every trip I take I see one.
 > Roof concern?
