RV.Net Open Roads Forum: Class C Motorhomes: Opinions on diesel vs. gasoline
 > Opinions on diesel vs. gasoline
Page of 5
klutchdust
Orange, California
Posted: 08/11/21 09:02am Link  |  Quote  |  Print  |  Notify Moderator
Drew wrote "From a maintenance and repair and engine life perspective, the gas engines are just fine. They're unlikely to be worn out in a motorhome, and certainly not before the house part is very very tired and well-used."
Absolutely. The V-10 has been a proven engine that can easily take 300K with regular maintenance. I personally would not go with the new engine Ford put out until it proves itself. As always the public becomes the testing grounds for what works and what doesn't.
Don't spend $$ on a diesel because you see the difference in mileage ratings. As soon as it goes in for service your $$ saved goes to the mechanic. My Cambria ,30ft. towed either my Jeep or a 16 ft. trailer loaded heavy with no problem. Hills are hills, as was said, how fast do you want to go up hills.
I had my eye on a super C but never drove one to see what the engine noise would be like. That vehicle would need to go to a truck shop for maintenance. Tires? How much are they alone.
Rent what you have in mind for a weekend, money well spent.
cbigham
orange , CA
Posted: 08/11/21 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Had a super c funmover 39c with c7 engine. Loud doghouse but not too bad. That was an 04 and when diesels started turning less reliable. Had a heui pump main shaft cavitate and send metal shards into injectors. 6200 bill, warranty. Apparently things haven't gotten much better, camp buddy told me last week his common rail Dodge Cummins did something similar. He was out of warranty.
Purely anecdotal, most of the vehicles I see broke on interstates these days are large trucks and a good number of diesels. Considering the numbers of cars out there, I find that interesting. I wouldn't buy a new diesel unless I had to. Gotta call a guy with a PhD to fix anything out of the ordinary. Not every station has diesel. Not every dealership or common repair shop can fix your brand of diesel. Almost every town with a dealer has a Ford shop. I also don't miss needing a truck stop to fill up both side tanks. I get 8,9 mpg on the '17 v10 towing a jeep. Good enough. Small enough to get into campgrounds I want.
jaycocamprs
Ringgold Georgia
Posted: 08/11/21 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
RetiredRealtorRick wrote:
A diesel in a Class C is a lot different than a diesel in a Class A. All the noise and heat is in front of you in a Class C, but far behind you in a Class A DP. I love diesels, but don't want it in my face.
Noise and heat wont go away just because it's a gas burner. The newer diesels aren't as loud as the old ones. And a Super C on a medium duty truck chassis will be easier to work on that a Ford or GM van chassis.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
BillyandKris
Arkansas
Posted: 08/11/21 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
Thanking everyone for replies and awaiting more. Interesting reading. To clarify: we tow a 29.5 Arctic Fox FW(built heavy) with a 2017 Ford F250. We are only interested in the Nexus Super C Wraith 32W because that's the shortest Super C out there that doesn't have a "fold up" bed or a Jayco Greyhawk 29MV only with the NEW Ford engine. BTW I AM the wife!! LOL
Posted: 08/11/21 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
There’s resale too.
Most Super C owners are towing something. From my causal observations anyway.
Diesel = better resale. Likely way better in a Super C
2017 Heartland Torque T29
bobndot
Posted: 08/11/21 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
If it matters to you. Compare insuring , repairing and parts cost of a super C to a Greyhawk E450.
kwplot34
home
Posted: 08/12/21 12:57am Link  |  Quote  |  Print  |  Notify Moderator
Had several class C with the V10 engine, the engines never gave us any problems, But, they were noisy, lacked power going up hills, no room between the seats because of the dog house, put a lot of extra heat in the cab, always down shifting. Now we have a Super C, a Thor Omni XG32 on the Ford F550 cab and chassis with 6.7L diesel, It drives and handles so much better than the van chassis, it's much quieter, plenty of room between the seats, no heat in the cab from the engine, rarely down shifts and goes up and down hill's or mountains with ease.
Would not own a gasser again, night and day difference.
pianotuna
Regina, SK, Canada
Posted: 08/12/21 02:03am Link  |  Quote  |  Print  |  Notify Moderator
Super C with a 176 inch wheelbase would be hard to drive. A 26 or 27 foot drives as if it were a full size car.
Regards, Don
pnichols
The Other California
Posted: 08/12/21 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Size versus chassis type does matter ... our V10 24 ft. Class C on it's overkill E450 drives very well:
1. Cab does not heat up due to built-in heat shields and floor air conditioning.
2. Pulls our 12-13K lb. total weight just fine due to it's high differential ratio, and we pass plenty of crawling diesels in the mountains.
3. Has big brake swept areas.
4. Has a large diameter driveshaft for no vibration.
5. Has a strong frame to prevent frame twisting on rough roads.
6. Has good side-to-side stability due to a wide rear dually stance versus it's height, plus it's heavy suspension.
7. Cruising engine speed is at a reasonable ~ 2200 RPM, so we can't hear or feel the V10 and I can control downshifting via my gas foot and it's convenient tow-haul mode button.
No way would I want a heavy diesel engine in our small and nimble motorhome that can be repaired/serviced just about anywhere, anytime ... affordably.
Phil, 2005 E450 Itasca Spirit 24V
bobndot
Posted: 08/12/21 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
I think Amazon has come to the realization regarding the Sprinters. They are replacing them with the Dodge PM and Ford Transit.
Page of 5
