RV.Net Open Roads Forum: Tech Issues: TPMS valve stems issue
 > TPMS valve stems issue
Blazing Zippers
North Idaho
Posted: 08/11/21 08:43am Link  |  Quote  |  Print  |  Notify Moderator
I installed a TST TPMS set of tire monitors on our trailer, and they work well. The wheels are fancy aluminum rims that came on the unit.
However, the valve stems leak due to the centrifugal force placed upon them. I've replaced them, but again, they leak.
Apparently, I have to get a metal type of valve stem installed on the wheels, but finding the correct brand and type is a mystery as the tire shops don't speak "valve stem."
Anyone with knowledge please get back with a brand of stem or where I can get info???
Thanks........................
RoyF
Fayetteville Arkansas
Posted: 08/11/21 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Many tire stores have metal stems: Discount Tire, for example.
bob213
Fresno, CA
Posted: 08/11/21 10:35am Link  |  Quote  |  Print  |  Notify Moderator
I used xtra seal 17-428 from O'riellys
xtra seal
or from here:
17-428
bob213
Fresno, CA
Posted: 08/11/21 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Not to hijack this thread but does anyone know if you need to replace metal valve stems when you get new tires or can you continue to use the old ones?
QCMan
Independent Republic of Horry
Posted: 08/11/21 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Depending on your rims the search can be easy or very hard. The easiest route is metal stems that tighten on the inside of the rim. Get the shortest stems that are long enough to let you mount your sensors. Best way is to put your spare on the trailer (presuming that you don't have a matching rim on the spare) and break the bead on the tire and try various stems. They are cheap enough to get a few different ones and then get a set of what works. If you have a steel spare that is a real easy one. If you get other than brass stems, use a tiny bit of dielectric grease on the threads to inhibit corrosion. Good luck.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
rlw999
Washington State
Posted: 08/11/21 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
If my tire shop didn't know what I meant when I said "I'd like to replace these with metal valve stems", I'd find a new tire shop.
I had the rubber valve stems replaced at a local Les Schwab store, I don't know what brand they are, I just said "Replace these with metal valve stems, and rebalance the wheels before you put them back on".
CA Traveler
The Western States
Posted: 08/11/21 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
X2 Run don't walk from that place.
2014 Grand Cherokee Overland
Bob
BarneyS
S.E. Lower Michigan
Posted: 08/11/21 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
Moved to Tech Issues forum from DIY.
punomatic
Pacific Northwest
Posted: 08/11/21 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
Blazing Zippers wrote:
I installed a TST TPMS set of tire monitors on our trailer, and they work well...
However, the valve stems leak due to the centrifugal force placed upon them...
When I installed TST TPMS on my trailer, the instructions clearly stated they are only to be installed on metal valve stems. Any reputable tire shop should be able to install metal valve stems for you.
DW and Me
2016 Riverside White Water Retro 195
2014 Nissan Titan SL Crew Cab
Formerly, I used to work for the department of redundancy department.
Life in Black and Blue
punomatic
Pacific Northwest
Posted: 08/11/21 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
Deleted dual post.
