RV.Net Open Roads Forum: Tech Issues: TPMS valve stems issue
 > TPMS valve stems issue
handsome51
Baytown
Posted: 08/17/21 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
QCMan wrote:
Depending on your rims the search can be easy or very hard. The easiest route is metal stems that tighten on the inside of the rim. Get the shortest stems that are long enough to let you mount your sensors. Best way is to put your spare on the trailer (presuming that you don't have a matching rim on the spare) and break the bead on the tire and try various stems. They are cheap enough to get a few different ones and then get a set of what works. If you have a steel spare that is a real easy one. If you get other than brass stems, use a tiny bit of dielectric grease on the threads to inhibit corrosion. Good luck.
I erased my post because I hit the wrong button
handsome51
Baytown
Posted: 08/17/21 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
bob213 wrote:
Not to hijack this thread but does anyone know if you need to replace metal valve stems when you get new tires or can you continue to use the old ones?
I get new metal valve stems when I get new tires because of the old rubber seals on the old valve stems
CA Traveler
The Western States
Posted: 08/17/21 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
My MH brass stem seals are replaced with new tires.
2014 Grand Cherokee Overland
Bob
