RV.Net Open Roads Forum: Class C Motorhomes: 1984 Ford Honey
 > 1984 Ford Honey
sputterbug10
illinois
Posted: 08/11/21 09:31am Link  |  Quote  |  Print  |  Notify Moderator
I'm looking at buying a 1984 Ford Honey. I don't know much about these. I wonder if you all think it worth the $6000 she wants for it. The listing says, "1984 honey 23 ft motorhome rv. I hate to see it go always been good to me just time for something bigger. Has lots of work done over the years but it was done right not slapped together and painted! Every window or seam is sealed with rv lap sealant the roof was painted with roof sealer so no water leaks.Up frount above the cab was rebuilt from the tin to the paneling with new insulation as the same for the back wall in the bathroom. It has a new refrigerator electric only but all the other appliances work as they should including furnace,and ac will freeze you out. As for the truck all the work was done professionally it has new exhaust manifold gasket, both fuel tanks, water pump,voltage regulator, u joints,rubbor brake hoses frount and rear,steels in good shape,frount and rear wheel bearings serviced with new seals,all brakes have been inspected good with new rear wheel cylinders and hardware,all fluids front to rear changed,tires are only 2 years old." Thank you.
jdc1
Rescue, Ca
Posted: 08/11/21 10:12am Link  |  Quote  |  Print  |  Notify Moderator
37 year old wooden box with 6mpg drivetrain. Hmmmm.....
Beverley&Ken
Tottenham,Ontario
Posted: 08/11/21 10:26am Link  |  Quote  |  Print  |  Notify Moderator
First of all, it’s 37 years old. It sounds like they have done a lot of work and correctly, But you would want to have that verified and that work is not hiding anything more serious, ie water damage in lower parts of the walls and floor.
You say that you are not familiar with the units, so I would recommend a GOOD RV inspector to completely go over the vehicle. They could possibly advise on the value $$. There still could be more and costly repairs possible in the near future.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
QCMan
Independent Republic of Horry
Posted: 08/11/21 10:34am Link  |  Quote  |  Print  |  Notify Moderator
I think the decimal point is in the wrong place! Unless it is showroom condition, a 37 year old rv of any form would probably not be worth that amount unless it is an Airstream and even they have had bad years. I have had sellers try to put value on their memories but I don't care to pay for them. Keep looking.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Monterey, California
Posted: 08/11/21 10:36am Link  |  Quote  |  Print  |  Notify Moderator
That’s an OLD RV. If you want a project, yes. If you want to go camping,..
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Posted: 08/11/21 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Could be decent.
Things that stick out are it obviously rotted out front and back to need “rebuilt” and no L.P. fridge means basically no fridge without being on shore power or setting up a big battery system.
That, and it’s carbureted and the 80s were the absolute low point in automobile power and reliability. Imo.
That’s the bad, aside from other things that can’t be gleaned from the add. You can find the good in it.
Personally, no one should have put all those repairs into that old of a previously rotted out RV, so I’d be super skeptical why all the money spent recently and now for sale.
No mention of miles or major maintenance/repairs. Like transmission namely.
2017 Heartland Torque T29
pianotuna
Regina, SK, Canada
Posted: 08/11/21 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
No.
Regards, Don
Bordercollie
Garden Grove, CA, USA
Posted: 08/11/21 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
Bias belted proper size 8 ply tires are hard to get, many change wheels to size and type that fit modern steel belted tires. House box hardware, tail light lenses, etc. are collector's items. Save your money to buy a much newer current brand rig that has market value.
Posted: 08/11/21 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
That’s an excellent place to start…”Let me see the maintenance records.” Next I’d check the date codes on all the tires. Wanta bet on that? I’ll guess 5 years or older.
Tyler0215
Iowa
Posted: 08/11/21 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
She wants $6000 for the memories. Way overpriced, but she would be insulted if you offered what it is worth. $500 max.
 > 1984 Ford Honey
