RV.Net Open Roads Forum: Dinghy Towing: 2016 ram 1500 toad
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  All
 > 2016 ram 1500 toad
dodge guy
Bartlett IL
Posted: 08/11/21 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Hello. Wondering if anyone is flat towing one of these. If so I’m looking for the weight (I will get it weighed when I’m out and happen to see a scale). Until then just wondering if you are towing it and what are you towing it with?
Mine is a 1/2 ton Big Horn Hemi, not stripped, but not loaded. I’m guessing around 5200 lbs empty.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
navigator2346
Wa and points South
Posted: 08/11/21 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Look on your door frame for the weight
NamMedevac 70
Reno
Posted: 08/11/21 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
Are you going to flat tow the ram behind a motorhome??? I may need to flat tow or use a car carrier for my 2001 Dodge Ram 1500 behind a 2019 Ram 1500 V8 if that is even possible. May be too heavy for a UHaul car carrier according to their website.
dodge guy
Bartlett IL
Posted: 08/11/21 11:59pm Link  |  Quote  |  Print  |  Notify Moderator
Nope, not on the door frame. Only the GVWR.
dodge guy
Bartlett IL
Posted: 08/12/21 12:01am Link  |  Quote  |  Print  |  Notify Moderator
That is the idea. I know I will have to replace the 5k lb hitch with a 7500lb hitch. The MH when loaded for a trip has the capacity to tow more than 5k lbs because I’m 1500lbs under the GCWR.
Monterey, California
Posted: 08/12/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
I see quite a few half tons being towed by MHs. Tahoes too.
rlw999
Washington State
Posted: 08/12/21 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
If you're towing with the "12 Forest River Georgetown 350TS" in your profile, you'll be pretty close to maxing it out with your 5200 lb toad. If you had to put it on a 2000 lb car carrier (like if it's a 2WD and not flat towable), then you'd be way overweight.
The GCWR for that chassis is 26,000 lbs, so if you're 1500 lbs under the 22,000 lb GVWR, that only leaves 5500 lbs of tow weight.
rjstractor
Maple Valley, WA
Posted: 08/13/21 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Sounds pretty sketchy. I once towed a little Focus behind a Chev 2500HD and had a couple of white knuckle moments stopping in the rain. You could do a fancy tow bar setup with a braking system but for the same money or less you could just buy a flatbed car hauler. Sounds like you're doing a one time move? Might be cheaper just to have it shipped.
NamMedevac 70
Reno
Posted: 08/13/21 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for info rjstractor
