RV.Net Open Roads Forum: Tech Issues: Solar maintainer.
 > Solar maintainer.
Crazy Ray
Monroe,La
Posted: 08/13/21 11:19am Link  |  Quote  |  Print  |  Notify Moderator
NO
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
Boon Docker
Posted: 08/13/21 11:41am Link  |  Quote  |  Print  |  Notify Moderator
Go for the 10 watt unit. Just make sure one of the battery cables is disconnected over the winter.
frankwp
Calgary, AB, Canada
Posted: 08/13/21 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
I've always disconnected the fully charged battery every fall & left it for the winter. In the spring, the battery isn't noticeably discharged. I just replaced the old battery at 11 years, but even so, it still had some life left in it.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
Boon Docker
Posted: 08/13/21 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
I do the same. My pair of GC2's discharge less that 10% over the winter.
pianotuna
Regina, SK, Canada
Posted: 08/13/21 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
fj12ryder,
five watts per 100 amp-hours of storage is the bare minimum. No need for a controller.
Regards, Don
RLS7201
Posted: 08/13/21 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have this solar charger on the dash of my Pick Up all winter long while snow birding for 3.5 months. Been using it for about 6 years with no problem.
At first I questioned if 1.5 watts was enough but so far so good.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
2oldman
NM
Posted: 08/13/21 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
I doubt 0.1 amp for maybe a few hours/day would do much of anything. You may want to check the battery voltage and see if it is actually doing anything.
fj12ryder
Platte City, MO
Posted: 08/13/21 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
fj12ryder,
Thank you for the info.
Howard and Peggy
"Don't Panic"
RLS7201
Posted: 08/23/21 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
Doubt all you want but it does keep the battery topped off for over 3 months. Before the 1.5 Watt charger, the battery wouldn't start the truck after sitting for over 3 months. Now when we return home the truck starts. Next spring, I will take a voltage reading of the battery.
Richard
fj12ryder
Platte City, MO
Posted: 08/23/21 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Well, FWIW, I unearthed the ol' amp meter and checked the lines coming off the battery. With the OEM battery disconnect set to Off, the draw was 0.01 amp. With the OEM battery disconnect set to On, I had 2.2 amps of draw. More than enough to drain the battery fairly quickly I believe.
On our older Fuzion, the battery disconnect only disconnected major things, there was still enough of a draw, I never measured it, that it would drain the battery down in a week or two.
 > Solar maintainer.
