RV.Net Open Roads Forum: Class A Motorhomes: Mirada Select Steering
 > Mirada Select Steering
choudrantpd
Ruston,La
Posted: 08/13/21 09:16am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2017 Mirada Select 37TB with app. 8,000 miles. It seems to drift as if the steering has slack when driving. It also has the Safety Plus steering stabilizer installed. The recommended tire pressure on the 22.5 tires is 110 psi and I usually run around 100 psi. I was curious if any others with a gasoline motorhome on the Ford F-53 chassis has this problem. I am contemplating taking it in to check the steering and alignment. If it is just an inherent characteristic of the Ford chassis, I will save my time and money rather than taking it to have the steering checked.
Thanks for any input or information
way2roll
Wilmington NC
Posted: 08/13/21 10:02am Link  |  Quote  |  Print  |  Notify Moderator
A few thoughts; there is no alignment done once the MH is built and the recommended pressure is often wrong. The best way to know what PSI you should be running is to weigh your rig as loaded for travel (either 4 corners or at least axle weights) and adjust PSI based on the tire manufacturer's guide.
I did all that and my gassers still rode like I was trying to steer a greased elephant on a muddy hill. The best remedy for this that I found was doing the CHF.
RLS7201
Posted: 08/13/21 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
The most prominent reason for what you're feeling in the steering wheel is improper toe-in setting.
The toe-in can be set with a tape measure and 2 straight pins. Never had a tape measure get out of calibration, GRIN. About 3/16" toe-in is correct.
If you are interested in doing this yourself, let me know and I'll explain further.
The CHF costs nothing for the rear axle but the front axle should have longer links added when doing the CHF.
Do the above mentioned items before throwing $$ at the issue.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
wolfe10
Posted: 08/13/21 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
Toe and caster both affect tracking.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
georgelesley
Tennessee
Posted: 08/14/21 04:30am Link  |  Quote  |  Print  |  Notify Moderator
Add some caster when alignment is done. We added 2* with Ford hotline and truck shop manager approval over 30000 miles ago, no problems. Also did CHF on both ends and added rear trac bar. Wander and tail wag are gone.
For front end wander, caster solved that. For sway, CHF, for tail wag, rear trac bar
George & Lesley
2014 Itasca Sunova 33C, 2019 Jeep Cherokee Lattitude Plus toad, Demco/SMI towing system
chuckftboy
Fleming Island, Florida
Posted: 08/14/21 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
You should first check that your Safe-T-Plus is installed correctly and has been adjusted to drive straight.
2019 Horizon 42Q Maxim Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
Nodaker
North Dakota
Posted: 08/14/21 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
Since the only dumb question is the one not asked; What is 'CHF'?
Nodaker
2010 Jayco Melbourne 29D
2011 Chev Colorado dinghy
RLS7201
Posted: 08/14/21 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
Cheap Handling Fix...........It is the relocating of the sway bar links to make the sway bar appear shorter to the chassis. Controls sway better.
Richard
way2roll
Wilmington NC
Posted: 08/15/21 07:40am Link  |  Quote  |  Print  |  Notify Moderator
Richard
The F53 chassis comes with 2 sets of holes for the sway bars. From the factory they are set to the longer holes which allows for more sway. Moving them to the shorter holes tightens it up. This does nothing to the suspension travel but rather firms up the handling and sway. Biggest improvement I ever had on my gasser MH's and the best part, it's free and takes about 20 minutes.
donkeydew
OR
Posted: 08/15/21 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
is this your first large m.h.? if it is you may be over driving it.
you need to relax your grip on the wheel and look farther down the road.
this will help on the sawing of the steering wheel.
