RV.Net Open Roads Forum: Tech Issues: Dexter Axles
 > Dexter Axles
Bluedog
Colorado
Posted: 08/13/21 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
Most newer trailers come with Dexter EasyLube Axles. These are supposed to simplify the requirement to lube the bearings every 12 months by applying grease to the Zerk fitting. However, most "experts" recommend removing the hub and pack the bearings manually.
I did that on my previous trailer with standard hubs and fail to see any advantage to say there is an improvement in servicing.
Monterey, California
Posted: 08/13/21 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
I..."fail to see any advantage to say there is an improvement in servicing."
You are not alone! lol
Mike134
Elgin, IL
Posted: 08/13/21 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
before the thread grows jump to one of these.
https://www.rv.net/forum/index.cfm/fuseaction/search/parms/sw%7Bez%20lube%20axles%7D%7Ckm%7Bexact%7D%7Ckl%7Bm%7D%7Cfm%7B%7D%7Cpd%7B365%7D%7Cma%7B%7D/sr/1.cfm
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
Lynnmor
Red Lion
Posted: 08/13/21 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
It is only a sales gimmick.
Second Chance
Wherever...
Posted: 08/13/21 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Clicky: Link
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
fj12ryder
Platte City, MO
Posted: 08/13/21 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
I don't see anything wrong with them, but they are pretty unnecessary. How often do you repack the bearings in your other vehicle wheel bearings? If bearings are well packed, and the mis-named "preload" set, they don't really need any maintenance for quite some time. If I did 10,000 miles per year I'd probably do mine every two years, but I don't do that many miles so it's usually four years or so. The mandate for annual bearing repack is a CYA by the builders.
I do my trailer bearings every few years, and have never had any issues with that timetable. YMMV.
Howard and Peggy
"Don't Panic"
Cummins12V98
on the road
Posted: 08/14/21 08:17am Link  |  Quote  |  Print  |  Notify Moderator
5 years is simply pumping in new grease and when converting to oil bath the bearings looked new along with the races. This is full timing and using AMZ/OIL grease. I have disk brakes so no worry about contaminating my pads. I won't own drums so a non issue for me.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ferndaleflyer
everywhere
Posted: 08/14/21 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 1999 tri axel trailer outside that has well over 100,000mi on it and just went on an 1100mi trip. It weighs around 10,000lbs loaded and the Dexters have NEVER been greased or failed.
Vintage465
Prunedale CA.
Posted: 08/14/21 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
I was originally really please to see EZ-Lube set up. Seems really nice to just jack up the axle spin the wheel and gently grease up. But the reality is the hub is full of grease causing it to heat up as you bomb down the road. There are "in my opinion" a couple factors that can cause fouled brakes due to grease. 1. Hot day, all day driving. That hub gets hot and the pressure causes the grease to force out at the path of least resistance. 2. If you have a lot of miles on your grease seals, then go on a long drive on a hot day, I think it increases your odds of fouling the brakes. 3. I hear the little rubber plug in the dust cap is suppose to be the pressure relief, but.......I think that's a pipe dream. I lost three of four sets of brakes to this and I will be packing my wheels by hand. For all you guys that have never had an issue.....great for you. Glad it works for you but it just costs me money I'd rather spend on something fun.
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
jodeb720
Denver
Posted: 08/15/21 09:11am Link  |  Quote  |  Print  |  Notify Moderator
I have them on my 5er - and annually pull and inspect them.
the rubber plug on them routinely breaks down and I have to replace it.
A couple of years ago, i had checked the plugs and they were ok, but when I arrive at my destination, two had broken and that meant dirt could have contaminated the bearings.
Off came the tires, repacked the bearings after a good cleaning to be sure no dirt got inside of them.
I like the idea, but in reality the old school checking and packing annually reduces the amount of excess grease the will expand with heat to a minimum. And, as others have said, it'll foul your drum brakes if it expands too much.
 > Dexter Axles
