RV.Net Open Roads Forum: Tech Issues: Dexter Axles
 > Dexter Axles
Lynnmor
Red Lion
Posted: 08/15/21 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
ferndaleflyer wrote:
I have a 1999 tri axel trailer outside that has well over 100,000mi on it and just went on an 1100mi trip. It weighs around 10,000lbs loaded and the Dexters have NEVER been greased or failed.
Your trailer was built before the bottom of the barrel Chinese bearings were used. I have had the cheap junk bearings fail in less than 8,000 miles and actually were beginning to fail at the first revolution because of defects. I hope that others ignore your lack of maintenance and do the right thing.
ferndaleflyer
everywhere
Posted: 08/15/21 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Really?
Lynnmor
Red Lion
Posted: 08/15/21 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Really?
Yes, really. Unless you actually do the work and know what is going on, you will remain clueless.
ferndaleflyer
everywhere
Posted: 08/16/21 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Here is one for you. My friend has had tires blowing on one side of his trailer on about every long trip. Even changed one of the axels. I recently while following him noticed that one of the rear tires was wobbling. Loose wheel, no. bent rim no. Loose or worn bearing, no. So repacked bearings and re installed wheel, still wobbled. Put another wheel on it, still wobbled. Removed the drum assembly from the other axel and installed it on that axel---wobble GONE. Cleaned the drum bearing area real good and discovered that the milled, drilled, whatever wasn't machined correctly. Put on a new drum and problem was gone. Trailer was 6 years old--China drum?
whjco
Lexington, KY
Posted: 08/22/21 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have EZ Lube axles but always periodically remove, clean, inspect and hand repack all of my trailer bearings no more than every couple of years. I recently pulled the bearings on my trailer I use for transporting my railroad motorcar and the trailer had been sitting for about a year. Condensate in one of the bearings had created a rust spot on the race and on a couple of the bearing rollers. Had I not found this, I could have ended up on the side of the road with a bearing failure.
There's no substitute for proper maintenance.
Bill J., Lexington, KY
2006 Starcraft 2500RKS 25' Travel Trailer
2015 Ram 2500 Big Horn 6.7 Cummins.
Dusty R
Charlotte Michigan 48813
Posted: 08/22/21 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a new tandem axel trailer, and one of the tires was wearing one side of the tread. I found that U-bolts on that end of the axel had not been tightened to the leaf spring and had slid a little on the spring, and had worn those U-bolts. I put new U-bolts on it, and made sure they were tight.
That was 10 to 15 years ago, and I'm still using that trailer.
ferndaleflyer
everywhere
Posted: 08/22/21 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Lynmor I doubt that you know any more about working than I do---That being said you have a lot of nerve to call me or anyone else clueless just because we didn't do it your way.
falconbrother
North Carolina
Posted: 08/23/21 07:27am Link  |  Quote  |  Print  |  Notify Moderator
I use them as advertised and they work great. I'm not pulling those hubs to outsmart the engineers, unless the rubber plug fails and there's evidence of contamination.
Bluedog
Colorado
Posted: 08/24/21 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
My old trailer had regular (old fashioned)bearings and I hand packed them every few years. Had plenty of experience from bearings on cars.
It looks like the EZ Lube is a different breed of cat. From what I have gleaned from the Internet is that the inner bearing doesn't come out like the old style but requires a tool to break it loose.
I assume that removal of the hub is about like the old ones with a retainer and nut.
Haven't seen any decent instructions on the job but I am a little hesitant to tackle it without knowing what I am doing. All you see is hit the Zerk with a grease gun and you are good to go. Question is how far?????
Anybody have any suggestions or pointers?
Lynnmor
Red Lion
Posted: 08/25/21 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Bluedog wrote:
arings on cars.
EZ Lube is simply a hole drilled in the spindle with a grease fitting in the outer end. A hole is drilled in between the grease seal and the inner bearing to connect with the center hole. No other changes have been made to the spindles except for a change in the retainer (cotter pin) so it allows for the grease fitting. Some grease may push out of the grease seal causing brake contamination, many seals and sealing surfaces are less that perfect. In order to get fresh grease thru the outer bearing, you need to pump a considerable amount to flush the inner bearing, fill the cavity and then flush till fresh grease goes thru the outer bearing. I don't use the silly things, they are nothing more than a sales gimmick.
 > Dexter Axles
