RV.Net Open Roads Forum: Tow Vehicles: Jeep Gladiator Overland Tow vehicle
Search only in Tow Vehicles
 > Jeep Gladiator Overland Tow vehicle
Max's Mom
DFW
Posted: 08/13/21 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
Hello, I am new to the forum, but not RVing. New to towing, always had a motorhome. I have a Jeep Gladiator Overland. 8-sp Auto trans, with tow package, class IV hitch. Manual states 6,000# tow ability, 600# hitch weight, 1083# max payload, 11,100 GCWR. Specs state a frontal area of 40ft. I have a Redarc Tow-pro Elite Brake Controller installed. I want to tow a FR Surveyor Legend 202RBLE, dual axles, UVW 4931# (brochure), hitch weight: 497#, CCC: 2566# (I doubt I would ever load this much) ext. height 11'2", ext. width: 96", ext. length 24'4".
I plan on using an Andersen WDH with Sway control. I don't load my truck down, normally solo travel or only with one other person. Please comment on this rig so I can better figure out if this is the correct tow vehicle for this trailer or visa/versa. I haven't ordered the trailer but do own the 2021 JT. Thanks for your comments!
rjstractor
Maple Valley, WA
Posted: 08/13/21 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
If you want to stick with all the specced tow ratings, you would already be way over on frontal area. 40 square feet limits you to just a five foot high frontal dimension if the trailer is eight feet wide. I think you might bump up against your GCWR, hitch weight and payload limits as well. The Gladiator appears big and beefy, but the nuts and bolts beneath that beefy exterior, not so much.
Max's Mom
DFW
Posted: 08/13/21 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks. Something to think about.
Durb
NW
Posted: 08/13/21 11:13pm Link  |  Quote  |  Print  |  Notify Moderator
You may want to check Motor Trend's 2021 Truck of the Year comments regarding the Gladiator and towing. They tested Ecodiesel and Mojave trim versions towing a 5,200# Airstream with no WDH. Their comments were the Gladiator was scary and borderline dangerous.
If I was going to proceed, I wouldn't use the Andersen but would jump to a heavier hitch with more stout anti-sway capabilities. The actual weight of that trailer with options, propane tanks and battery will far exceed 5,000#.
Good luck and welcome to the forum.
Posted: 08/14/21 04:44am Link  |  Quote  |  Print  |  Notify Moderator
unless you have the diesel, the performance is pretty underwhelming for towing 1/2 ton truck sized campers with the milquetoast V6.
The one I did look at looked great for off roading. Looked like a Jeep when it comes to towing. (Soft suspension).
Too much trailer for a newb to handle behind that buggy, IMO.
Great vehicle. But a bit smaller camper is what I’d be after.
* This post was edited 08/14/21 05:17am by Grit dog *
2017 Heartland Torque T29
Posted: 08/14/21 05:16am Link  |  Quote  |  Print  |  Notify Moderator
Will say the axles are stout enough though and suspension can be stiffened up easy.
I wouldn’t count it out. Just know you may need to do a couple things to the Yeep.
Trans will make the most of the little engine and is a good unit for towing.
APT
SE Michigan
Posted: 08/14/21 09:07am Link  |  Quote  |  Print  |  Notify Moderator
If you care about the specs, you will be limited to low walled RVs. If the frontal area is the only spec you are willing to exceed, then you'll want to stay close to 4k dry, maybe 3500. Add 750 pounds to loaded weight and 200 to TW for nearly any TT in that weight range.
I the specs do not matter, you have plenty of power. There are aftermarket upgrades to improve most aspects of towing high walled RVs near/over various ratings.
* This post was edited 08/17/21 09:55pm by APT *
2017 Subaru Outback 3.6R
rexlion
Broken Arrow OK
Posted: 08/14/21 10:15am Link  |  Quote  |  Print  |  Notify Moderator
Are you sure you wouldn't like a Casita? I think the Gladiator with Andersen would do fine with one of those low-profile 'egg' trailers.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
goducks10
There
Posted: 08/14/21 10:26am Link  |  Quote  |  Print  |  Notify Moderator
I'd look at R-Pod style TT's and keep stickered UVW's around 3500 lbs. You want a narrower style TT for less wind drag. The rounded front section on R-Pod style TT's will help as well.
I would even look at this https://forestriverinc.com/rvs/travel-trailers/flagstaff-e-pro/E19FD/3557
dodge guy
Bartlett IL
Posted: 08/14/21 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
You’ll be at 6k lbs loaded for a trip. That’s a lot of weight to ask of the 3.6. Even with its good power it’s taxed just hauling around the empty Gladiator. This is where Jeep dropped the ball by skipping the 5.7 Hemi as an option. And only offering the 6.4 on the 4dr Wrangler! A 5.7 is all that would be needed for the Gladiator.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
