RV.Net Open Roads Forum: Fifth-Wheels: Fridge lock
 > Fridge lock
prowlerregal
Williamstown,NJ
Posted: 08/13/21 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
I'm putting in a residential fridge in my 5th wheel.For you guys who have already done this what are you using to keep the doors locked while on the road?Please let me know what you are using and where did you get it from? Thanks!If it matters it is a kenmore 11.6 cu ft
2014 3500 SRW 4X4 Ram
2006 King of the Road Royal Villa F33TS
Beverley&Ken
Tottenham,Ontario
Posted: 08/13/21 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
An easy solution would be from Walmart or others stores that sell baby and kids things. Child proof locks. Or even Velcro on the side of the fridge and doors.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
Campinfan
Washtenaw County, Michigan
Posted: 08/15/21 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
I use a bungee cord but mine has this weird end that you insert the bungee cord through the hole and then pull it down 90 degrees to a channel that locks it into place. I run this cord through the two side by side doors and the lower freezer door. Its called an adjustable bungee cord...
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
Campinghoss@51
Windsor NC
Posted: 08/16/21 04:30am Link  |  Quote  |  Print  |  Notify Moderator
I simply use a strap with the black quick snap fasteners. My handles are side by side so I just run the strap thru both and pull it tight. Never have had a problem with that set up.
Camping Hoss
2017 Open Range 3X 388RKS
2017 F-350 6.7 with hips 8'bed
Lucky & Lucie
R12RTee
Full Timing with a home base in FL
Posted: 08/16/21 06:10am Link  |  Quote  |  Print  |  Notify Moderator
The Fridge Fixer is what we use.
Fridge Fixer on Amazon
A bit pricey but a great product.
Our new RV came with Insignia appliances and the fridge does not have handles that can be used with a strap.
2021 DRV Mobile Suites 38RSSA
2021 Ram 6.7 HO
2012Coleman
Posted: 08/16/21 09:10am Link  |  Quote  |  Print  |  Notify Moderator
I'd be interested in the details regarding how you are replacing the current fridge with a residential one. I'm thinking of doing the same thing, but haven't gotten into the details
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
slider45
GA
Posted: 08/19/21 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Alright, I will show this to aunt. They got Insignia ref with no handle. I'm coming over this weekend to help them install the headache rack and tonneau covers on the truck.
gwalter
Colorado
Posted: 08/19/21 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
X2 This is a good product and we have the Insignia fridge also.
2010 Ram 3500 Laramie
2021 Bighorn 3120 RK
B & W Companion Hitch
Air Bags
prowlerregal
Williamstown,NJ
Posted: 08/25/21 09:34am Link  |  Quote  |  Print  |  Notify Moderator
2012 Coleman I just went online checking out 10 cu ft fridges out.A whirlpool 11.7 cu ft fridge came up.I checked my opening in my trailer.I had to trim the one side and top to make it fit.I also put a 2 x 4 I had a friend plane down to 1 5/16's to put under the front because the 1 foot stuck out for the door hinge.A couple of screens in the back to keep it for moving.I think it turned out great.I hope this helps.
 > Fridge lock
