RV.Net Open Roads Forum: Class A Motorhomes: rocker switch
sssooo
Ohio
Posted: 08/13/21 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2018 Fleetwood Bounder the rockerswitch fore the front blinds wont raise the blind it will go down NOT up.
I got the switch apart jumper to get it to go up. loohing for switch cant find one anywere the No. is 20a 12v 1711r no luck I need help
scott
enblethen
Moses Lake, WA
Posted: 08/13/21 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Can you see any other markings on your switch?
Look through the site. I am guessing it is on/off/on configuration.
Momentary on/off/on switches
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
larry cad
ohio
Posted: 08/14/21 06:34am Link  |  Quote  |  Print  |  Notify Moderator
This is a Carling switch. Amazon carries them. Does it look something like this?
Our Travel Blog
sssooo
Ohio
Posted: 08/14/21 07:59am Link  |  Quote  |  Print  |  Notify Moderator
My rocker works both up and down it has 6 termatals on the back?
Thanks. Scott
DrewE
Vermont
Posted: 08/14/21 08:19am Link  |  Quote  |  Print  |  Notify Moderator
The "20A 12V" nomenclature on the switch isn't part of its part number, per se, but the electrical ratings of the switch (12VDC at up to 20A). 1117 may be a date code for when the switch was manufactured--the 17th week of 2011. It might also be some sort of a part number or abbreviated part number.
How many electrical terminals are on the switch, and what size/type are they? What are the dimensions of the switch? How does it mount to the panel it's in? If you find a switch with adequate electrical ratings, the same contact configuration, a compatible physical mounting and electrical terminations, you can use it; you aren't limited to the specific manufacturer and model.
If there are six electrical terminals on the switch, it's almost certainly a DPDT switch. If there are three, it would likely be an SPDT switch. If it is internally illuminated, add two additional terminals for that--which are not essential for a replacement for operating the shade. In any case, I assume it's a center-off momentary switch, meaning you have to hold it depressed on one side or the other to make things happen.
sssooo
Ohio
Posted: 08/14/21 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
I looked again and I saw no. on the other side it was the Pat. no put that in and it took me rite to it got one
opnspaces
San Diego Ca
Posted: 08/15/21 11:17am Link  |  Quote  |  Print  |  Notify Moderator
Are you saying you successfully found a replacement switch?
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
sssooo
Ohio
Posted: 08/15/21 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
yes found it by using the US.pattan number.
sssooo
Ohio
Posted: 08/21/21 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Got the new switch it doesn’t work new switch has 3 terminal on it my switch has 6 terminals on it.
Is there a RV.salvage yards out there?
enblethen
Moses Lake, WA
Posted: 08/21/21 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Colaw in Missouri
colaw
Same switch you have should have the 6 pin depending on manufacturer. What switch did you get? Part and manufacturer?
