RV.Net Open Roads Forum: Class A Motorhomes: rocker switch
sssooo
Ohio
Posted: 08/24/21 01:29am Link  |  Quote  |  Print  |  Notify Moderator
1-800-322-8216 I called this no. And got the rite switch!
Posted: 08/24/21 05:06am Link  |  Quote  |  Print  |  Notify Moderator
Try this... Cycle the switch UP/DOWN UP/DOWN like 100 times while it is NOT connected. then re-connect and try again.
If it does not work, well at least it was FREE
if it does work consider
"Should I buy lotto tickets cause when you hot, you hot"
or
"Should I NOT buy lotto tickets because i used up my quota of LUCK for the month"
Worked for me, in Las Vegas, different switch and I did fairly well that week, Did not win big but did not lose either.
enblethen
Moses Lake, WA
Posted: 08/24/21 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Switch should be a momentary on/off/on double pole-double throw. It needs to reverse the DC to the blind.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
sssooo
Ohio
Posted: 08/29/21 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
I put in new switch and it still won’t work it just winds the blind up tight won’t bring it down I am it a lose!
Now the wife just tell me the other blind only goes 1/2 way bown don’t know
enblethen
Moses Lake, WA
Posted: 08/29/21 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
The center pins should go to the blind. Power should go to ends of switch and be criss-crossed to other end pins reverse blind motor.
Found good photo off back of switch Reversing switch
* This post was edited 08/29/21 05:16pm by enblethen *
