RV.Net Open Roads Forum: Tech Issues: "Groovy" flat fuses VS non-groovy
 > "Groovy" flat fuses VS non-groovy
Eskimo007
L'Orignal
Posted: 08/14/21 06:48am Link  |  Quote  |  Print  |  Notify Moderator
I recently needed to replace a 40amp DC flat fuse between my RV battery and inverter, and had the hardest time trying to insert the spare fuse that the original owner had provided. Upon (very) close inspection, I noticed that the replacement fuse although the exact same size and appearance as the burnt out one had some grooves on each side, whereas my replacement did not. Needless to say, trying to force the replacement in the holder brought no joy.
Does anyone know what the difference is between the 2 types? I'm thinking maybe slo-blow or not? Looking at the transparent casing of the fuses, I can see the inside is different.
Dusty R
Charlotte Michigan 48813
Posted: 08/14/21 07:08am Link  |  Quote  |  Print  |  Notify Moderator
Did you try turning the fuse around? But I don't know why a fuse would be directional.
Posted: 08/14/21 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
I think the only difference is the maker.. "Grooves" make it easier to grip with fingers.
I use tools to insert fuses. generally works
Compare the Tabs that come out of the fuse. I've seen some that I think are bigger.
NRALIFR
Truck Camping Out West
Posted: 08/14/21 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you’re talking about a blade type fuse, but you might want to clarify that before we get off too far in the weeds.
Is it one of these?
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450 ‘Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam types………..Let’s Go Brandon!!!
Eskimo007
L'Orignal
Posted: 08/15/21 10:04am Link  |  Quote  |  Print  |  Notify Moderator
It's a 40A like the Maxi. Will try to add a picture to my post that clearly shows the grooves above the blades on both sides.
(cant figure out how to post pictures, says link removed)
1drv.ms/u/s!AlUCXH-477GAipJtv8NIRuvampPKpg?e=bT3pNF
1drv.ms/u/s!AlUCXH-477GAipJuc1QtvC3nggC3QQ?e=AfB3RO
NRALIFR
Posted: 08/15/21 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Jacques, use this link to post a picture on this forum.
IMGUR Photoposting Link
Drag and drop your image, or use the SELECT button to navigate to the image on your device, and it will upload to the IMGUR host site. It will then give you a link that you copy and paste into the forum Quick Reply box.
opnspaces
San Diego Ca
Posted: 08/15/21 10:30am Link  |  Quote  |  Print  |  Notify Moderator
[image]Click For Full-Size Image.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
NRALIFR
Posted: 08/15/21 10:56am Link  |  Quote  |  Print  |  Notify Moderator
I don’t think I’ve ever noted that difference before, but I see what you mean now. If the device the fuse is for uses those grooves as a “key”, you can only use that style of fuse.
Most of the maxi fuses you can order on Amazon (that have decent pictures) appear to have the grooves, but that doesn’t necessarily mean that’s what you’re going to get.
I guess I would just take your old fuse to an auto parts store and buy one that looks the same.
DrewE
Vermont
Posted: 08/15/21 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think the grooves signify anything, nor ought they interfere with the fuse insertion. I think they're just an artefact of the way the prongs are manufactured on the one fuse (they appear to be laminated out of a couple thicknesses of metal on the one, vs. cut from a single thicker piece on the other). I might be wrong, of course, but it seems quite unlikely to me that they are significant.
Perhaps you simply weren't applying enough force to get the fuse into the socket? Sometimes these sorts of things can be really tight and need more persuasion than one would generally expect.
Fisherman
Angus, Ontario, Canada
Posted: 08/15/21 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
I'm going with what DrewE said, most likely makes for a tight positive contact.
