RV.Net Open Roads Forum: Tech Issues: "Groovy" flat fuses VS non-groovy
 > "Groovy" flat fuses VS non-groovy
ktmrfs
Portland, Oregon
Posted: 08/15/21 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
those "groves" in the blades are from the female receptical the fuses goes into. with 40A you MUST have very low contact resistance with the fuse, and the ONLY good contact surface is through the groves and the hopefully high contact force to the back of the receptical.
those Maxi fuses take a lot of force to install.
2011 Keystone Outback 295RE
D.E.Bishop
Eagle Rock, CA
Posted: 08/15/21 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
I'm with DrewE's first sentence. Those groves are not significant electricity wise. Just try a little harder to insert the new fuse.
It ain't rocket science.
I am adding to my original post as I was called away without being able to finish.
I have enough life experience(81years)and in the electrical field for 51 years, that I feel safe saying that the really odd ideas about shape of the blades and the plastic is just grasping at some really far away straws.
If it won't fit at all and there are absolutely no manufacturer marks on the original fuse, the solution is to replace the fuse holder or maybe contact the vehicle mfg or the mfg of the part and ask it the fuse is special.
Asking here has not accomplished anything concrete and doesn't seem likely after reading the response that follows mine just a waste of time.
* This post was edited 08/15/21 09:10pm by D.E.Bishop *
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
NRALIFR
Truck Camping Out West
Posted: 08/15/21 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Eskimo007 wrote:
It's a 40A like the Maxi. Will try to add a picture to my post that clearly shows the grooves above the blades on both sides.
(cant figure out how to post pictures, says link removed)
1drv.ms/u/s!AlUCXH-477GAipJtv8NIRuvampPKpg?e=bT3pNF
1drv.ms/u/s!AlUCXH-477GAipJuc1QtvC3nggC3QQ?e=AfB3RO
I think he’s talking about the areas I’ve circled, guys.
The replacement fuse doesn’t appear to have those same “grooves”, and if the device the fuse is for has a fuse socket shaped to accommodate those grooves, one without the grooves ain’t goin in!
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450 ‘Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam types………..Let’s Go Brandon!!!
ktmrfs
Portland, Oregon
Posted: 08/15/21 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
OK I take back my comments about the groves on the blades where it contacts the socket.
there are lots of mfg of these fuses anymore, and some are of questionable quality. IIRC harbor freight had to recall a bunch for safety issues.
first thing i would do is look at a bussman or littlefuse brand and see what they look like and if they fit.
Eskimo007
L'Orignal
Posted: 08/16/21 06:14am Link  |  Quote  |  Print  |  Notify Moderator
I think the grooves are much more obvious if you look at this picture, the fuse on the left, way-non-trivial grooves which no amount of coaxing even with pliers will bring any joy. 1drv.ms/u/s!AlUCXH-477GAipJuc1QtvC3nggC3QQ?e=AfB3RO
NRALIFR
Posted: 08/16/21 06:21am Link  |  Quote  |  Print  |  Notify Moderator
Jacques, can you take a picture of the location where that fuse is supposed to plug in?
If you can email me that picture, and the one you just tried to post, I’ll post them both for you.
I’ll PM you my email address.
Eskimo007
L'Orignal
Posted: 08/16/21 06:36am Link  |  Quote  |  Print  |  Notify Moderator
Cant take a pic right now, the RV it's in is out in New Brunswick. I'll forage around my folders, I might have taken one. Can you see the picture from the Onedrive link I posted? Esp the one looking top-down?
NRALIFR
Posted: 08/16/21 06:47am Link  |  Quote  |  Print  |  Notify Moderator
No, the image location you posted is on your cloud storage site, and it needs to be on a public image hosting site. I don’t use Onedrive, but I suspect it doesn’t allow that type of linking.
If you can email it to me I’ll post it for you. I can also help you figure out how to use the IMGUR link I posted.
NRALIFR
Posted: 08/16/21 06:52am Link  |  Quote  |  Print  |  Notify Moderator
Correction, I didn’t recognize the Onedrive link you posted. I actually can see the image if I copy paste it into a browser window. Here it is.
Eskimo007
L'Orignal
Posted: 08/16/21 09:33am Link  |  Quote  |  Print  |  Notify Moderator
So you notice those big grooves on the left one and not the right... I stopped by the local NAPA parts dealer to ask, he had some with grooves and some without but didn't know the difference. I also messaged Littelfuse, maybe they will enlighten us. "That's what I like about standards, there are so many of them!"
