RV.Net Open Roads Forum: Technology Corner: Forcing Garmin 890 to a different route?
 > Forcing Garmin 890 to a different route?
philh
Belleville MI
Posted: 08/14/21 08:04am Link  |  Quote  |  Print  |  Notify Moderator
When I go to pick up 5th wheel, the fastest route will take me through a major metropolitan city that I want to avoid. Modified route will only cost me an estimated 30 minutes or so.
How do I specify specific roads to travel?
enblethen
Moses Lake, WA
Posted: 08/14/21 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Add a via point! At times you need to delete it when getting close.
This is only way I have acheived routing away from questionable areas.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
2oldman
NM
Posted: 08/14/21 09:11am Link  |  Quote  |  Print  |  Notify Moderator
Input a set of coordinates to drive to, an address, a city.. whatever.
Jim-Linda
Livingston, TX
Posted: 08/14/21 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Download Garmins Base Camp software to PC, create route and send to GPS. You can move the routing to anywhere you want. Added step but custom routes.
Second Chance
Wherever...
Posted: 08/14/21 09:39am Link  |  Quote  |  Print  |  Notify Moderator
The newer Garmins also have a "Route Shaping" function. You go into a map of your route and touch places you want to transit. The GPS alters the route to go through those transit points. You can also do what I often do... let the GPS set the route it wants and just take the exit where you want to deviate. The GPS will freak out for a while, but will figure it out and recalculate the route. I drove, sailed, and flew for decades before GPSs and can still use a map when needed.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
fj12ryder
Platte City, MO
Posted: 08/14/21 09:54am Link  |  Quote  |  Print  |  Notify Moderator
This is what I would recommend. It is how I determine any route for the GPS. I never let the GPS determine the route, as it rarely goes where I want it to.
And Basecamp is free.
Howard and Peggy
"Don't Panic"
rexlion
Broken Arrow OK
Posted: 08/14/21 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
I like Second Chance's advice. It's really easy to force a GPS onto a different route... just take the different route, and the GPS is forced to go along! [emoticon]
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
Solo
NE Kansas/Central Florida
Posted: 08/15/21 06:29am Link  |  Quote  |  Print  |  Notify Moderator
Rob
Using Base Camp software might be your best solution but your 890 will allow "reshaping" as Second Chance describes. Much easier to do than setting waypoints with an older Garmin.
Solo
2011 Itasca Ellipse 42QD, 450 HP ISL Cummins
2012 Jeep JKU with SMI DUO Braking System
Our Travel Blog VolunteersWithAPurpose
