RV.Net Open Roads Forum: Truck Campers: Eagle Cap 1200 Weight on Ford F350
 > Eagle Cap 1200 Weight on Ford F350
Posted: 08/15/21 11:17am Link  |  Quote  |  Print  |  Notify Moderator
eagarant, so you know the numbers, both weights and capacities. You said you refuse to do more suspension work ( as I read your post) yet you’re asking how to haul a 3+ ton TC on a 1 ton dually.
I’m not following.
Hauling one of them on a (new or newer) class 3 dually is akin to hauling a 4000+ Lb camper on a 3/4 ton. It’s done all day long by many people. Question is can you accept driving a truck at or near its practical limits?
Another consideration is the pickup bed itself. TCs are tough on truck beds and the beds are made the same so the heavier you go, the more considerations or damage you may expect (vs a flatbed).
This appears to be a rhetorical question that you already have strong opinions about or against, so why the question?
2017 Heartland Torque T29
3 tons
NV.
Posted: 08/15/21 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
I can’t say I disagree much with the above, but the terms “3/4 ton, and 1 ton” (a relic of the 1940’s if even before) are fairly meaningless with today’s trucks… FWIW, it may be possible were one to judiciously order just the right configuration to end up with say a so called 1 ton truck capable of carrying a 3 ton camper and still be within the 14k# limit… Point is, the terms 3/4 and 1 ton are pretty much theoretical, thus short hand for a broad range of payloads - just saying,
3 tons
egarant
Mission Viejo CA
Posted: 08/16/21 08:40am Link  |  Quote  |  Print  |  Notify Moderator
I’m not following.
I'm against doing nickel and dime suspension add on's, I don't believe adding a sumo spring, air bags or Torklift stable loads are the proper or safe way to increase a trucks capability.
I currently drive my TC at it's practical limit, 600 lbs over my GVWR.
I've never experienced any TC I've owned damage any truck bed so I don't follow, it they are mounted correctly the truck bed should be fine.
My question was and still is....is anyone actually carrying a EC 1200 triple on a F350 dually.
2021 FORD F350 dually 4x4 with 4.30 gears
2013 Eagle Cap 950
480 Watts Solar, 2K Watt Xantrex Inverter, Reonogy MPPT Charge Controller, 250 amps of lithium batteries by LifeBlue
toddb
az
Posted: 08/16/21 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Deaver isn’t cheap, they were about 1/2 of the kelderman. I went with air, it’ll put that 1200 at unladen height.
Posted: 08/16/21 08:51am Link  |  Quote  |  Print  |  Notify Moderator
3 tons
Everyone understands that, or should, easily, if they have a truck. Wasn't the point of my post.
Posted: 08/16/21 10:30am Link  |  Quote  |  Print  |  Notify Moderator
egarant wrote:
I’m not following.
Agreed, that was your question, but it’s a leading question based on your first post, something like “no way in hades can a 1 ton dually haul a 1200 and I refuse to do any upgrades except Deavers.”
So to your point, I suppose this thread is merely out of curiosity and not any sort of consideration of actually hauling a 1200 with your truck.
(Which I would agree with, based on your weights with a 950, you are hauling ALOT more “stuff” than average. To be at 14,600 lbs with a gasser cc dually, you have over 6klbs worth of camper and “stuff”. Like close to 2000lbs of “stuff” beyond the wet weight of your 950. )
A 1200 with your stuff in it would be well over 7klbs.
egarant
Mission Viejo CA
Posted: 08/16/21 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
In my experience Deaver has always been a deal. They fabricated two 3 leaf overload spring packs, installed while I waited for $375.
So what Kelderman system did you install?
toddb
az
Posted: 08/16/21 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
They quoted me over 2k for a new spring pack. I put a 4 link in rear only, rides like 250 unloaded and lifts back to ride height loaded. I can dump either side and drop 4”, handy for the holding tank dumps. It’s very nice on sweeping turns as it’ll inflate/deflate either side and keeps the truck level when it wants to lean over. The truck is a 15 f350 drw, camper is af 992 and I pull an enclosed trailer.
3 tons
NV.
Posted: 08/17/21 12:29am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
3 tons
Interesting response…But begs the question, who is “Everyone”??
Posted: 08/18/21 09:53am Link  |  Quote  |  Print  |  Notify Moderator
3 tons wrote:
Grit dog wrote:
3 tons
Thought I covered that "if they have a truck."
