RV.Net Open Roads Forum: General RVing Issues: Putting new decals over old.
 > Putting new decals over old.
MURPHY55347
Savage, MINNESOTA
Posted: 08/14/21 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2018 Winnebago Vista 27N motorhome and a couple of the silver decals have spots on them that looks much like the mold you might see on Diamondshield. Otherwise they are in great shape. They are firmly adhered with no cracks. All other colors on the MH are fine. Can I put new decals over the old ones? I would probably use a different color just in case the spots might telegraph through.
Gdetrailer
PA
Posted: 08/14/21 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
If you want the new decals to fail even faster than slap them right over the existing decals.
Just like anything else in life, a key to everything is having a "good foundation", old decals are worn out, unstable which ultimately will result in damaging anything slapped on top of them.
Good prep by removing old will reward you with the longest life of your new decals.
There are specialized decal adhesive remover tools and chemicals that will make the removal and cleanup job go smoother..
If you don't want to put the time and effort into doing the job right, take it to a body shop and pay the price to get the job done correctly.
agesilaus
North Florida
Posted: 08/14/21 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
You can supposedly remove the decals with a heat gun and putty knife. I'd try that first.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
corvettekent
Marysville, WA
Posted: 08/14/21 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with Gdetrailer on this. Do it right the first time or you will be doing it again.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
Gooma
Iowa
Posted: 08/14/21 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
Yes you can use a heat gun and scraper to remove the decals. The trick is to get ALL the adhesive off also.
Posted: 08/14/21 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
I’d also remove the old ones first,,but if you’re putting matching decals on, they will last just as long on top of your current decals as they would otherwise and presumably look right.
2017 Heartland Torque T29
capacitor
California
Posted: 08/14/21 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
That would be Goo B Gone.
GMH
Canada
Posted: 08/15/21 09:06am Link  |  Quote  |  Print  |  Notify Moderator
Yes, a heat gun and plastic scraper blades (Titan is one brand) will get 98% of it off. And 3M makes an adhesive remover that can take the remaining glue off.
opnspaces
San Diego Ca
Posted: 08/15/21 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Yes on the heat gun and plastic blades. But be careful to not overheat with the heat gun. Wave it over the decal for a few seconds then take it off and try the scraper. If not loose wave for a few more seconds. the vinyl will go from stuck tight to easy to peel to way too soft to peel very quickly.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Posted: 08/15/21 11:26am Link  |  Quote  |  Print  |  Notify Moderator
And be careful on the thin siding on RVs and heat guns. They’re more susceptible to scorching or yellowing than painted vehicle panels or boat gelcoat.
Removal can involve any number of methods. Heat gun (sometimes I use a propane torch if handier), razor blades, fingernails, putty knives, eraser wheels and various solvents, from lacquer thinner/acetone to adhesive remover, wd40, gasoline, goo gone etc. I generally prefer stronger solvents. Less scraping and elbow grease.
Get your technique figured out on less conspicuous areas and know that it takes a smidge of sense and coordination to take heat and a razor blade to your vehicle or RV.
