RV.Net Open Roads Forum: Tech Issues: Best Cleanser for Condenser Cleaning for AC?
 > Best Cleanser for Condenser Cleaning for AC?
jodeb720
Denver
Posted: 08/15/21 09:22am Link  |  Quote  |  Print  |  Notify Moderator
I did a search - and there's a host of answers.
the most common were 409 cleaner, Dawn dishwashing soap, Simple Green.
What's the most effective cleaner to remove all the crud from the condenser/eveaporator?
Thanks
Josh
Tyler0215
Iowa
Posted: 08/15/21 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Water
jdc1
Rescue, Ca
Posted: 08/15/21 09:25am Link  |  Quote  |  Print  |  Notify Moderator
Tyler0215 wrote:
Water
Ditto. Regular household water pressure. No pressure washer!
opnspaces
San Diego Ca
Posted: 08/15/21 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Never cleaned mine because have only ever ran it maybe 5 times in the last 16 years. But I would just use plain water from the garden hose. All you're cleaning off is dust and dirt. There's no oil or other adhesives on there to require an actual cleaning agent other than water.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
DrewE
Vermont
Posted: 08/15/21 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
An old toothbrush or something similar to scrub with (carefully) can also be helpful.
Lynnmor
Red Lion
Posted: 08/15/21 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Since you are dealing with thin aluminum parts that are holding high pressure, it would be best to use a product that won't promote corrosion.
theoldwizard1
SE MI
Posted: 08/15/21 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
Vinegar ! Spray it on, let it sit 10-15 minutes and hose it off.
jodeb720
Denver
Posted: 08/15/21 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
@OldWizard,won't the acid in the vinegar corrode the fins?
Thanks guys. I took the 5er back to night - almost done with my floor - but I know the AC unit needs a good cleaning!
That's next weekend.
schlep1967
Harrisburg, PA
Posted: 08/16/21 08:58am Link  |  Quote  |  Print  |  Notify Moderator
I used this and it worked great and it's cheap at the local Wally World.
Condenser cleaner
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
wolfe10
Posted: 08/16/21 10:05am Link  |  Quote  |  Print  |  Notify Moderator
Any box store will have aluminum-friendly condenser/evaporator cleaner.
Rinse with fresh water.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
